Steve Neill scratch built 1/96 type 212
    • Nov 2025
    Well guys I started this 8 months ago. Many of you saw the first one running at the Regatta. Big Dave my partner in crime worked with me closely in the development of the cylinder just for this little boat. It uses his custom RCABS-R system and is a fine piece of work.
    Also many thanks goes to my friend David Merriman who I learned a great deal from over the years. He was always there when I needed him. And top it off he made the two types of props for the boat as well as deck fittings, scopes, ants and masts. In fact David now has the masters which survived the molding process and he plans to carry on with this kit in the near future.
    Basically the build consisted of masters made out of wire cut foam from templates and a card board center section of which all was glassed when to shape. followed by careful preening to produce the hull master. Much like the build on the type 17.
    All appendages are made from Alumilite originally carved by hand from PVC and the sail Balsa. Panel lines were achieved by using cart tape and lots of primer over them. Once dry I removed the tape and lightly sanded.
    All the hulls were laid up out of West Systems epoxy and glass from a two part silicone mold backed with more epoxy for the mother support mold.
    To learn more about it you can go to this link. http://subpirates.com/viewtopic.php?f=21&t=2263
    Unfortunately since I changed servers some of the pictures are missing. I backed them up and will replace them soon.
    What follows next is to get her wet, trimmed and ready for another one of my videos. This time with clear under water footage as I have a new under water camera.
    For now here is a few pictures. Two are near finished. The one in red primer is the hull before painting. Still a bit to do on the paint job. I stayed away from heavy weathering this time due to the fact that these boats seem to be always clean like a new Porsche.
    I'll post the video when I finish up this weekend. This is the fun part. It was a long build from scratch. Not an easy shape to make by hand. But I'm pleased.
    What's next? I'll think on it.
    Enjoy the pictures.
    Steve
  • stark
    • Jul 2006
    • 243
    Super Model Steve!!
    Brian
    Super Model Steve!!
    Brian
    • raalst
      • 1229
      Very nice weathering.
      Are
      Are the panellines recessed or do they stick out ?
      i.e. did you scribe them into the hull or did
      you stick some material to the hull to obtain
      them ?
      note to self : first read a post before asking...
        Thanks guys very much. I
        Thanks guys very much. I thought I might not make anymore scratch models until I saw this done. Now I'm thinking again. Can't stop now.
        But I have several kits to build so I'm going to finish those first and think about it along the way. German. WW2 is the idea. Or maybe Japanese?
        Anyway I plan a video shoot this weekend and will post when it's done. Couldn't have done this without BigDave and Merriman. It was a good team.
        Steve
        • pirate
          • 849
          Looks great Steve! See, you
          Looks great Steve! See, you do have fans here.
          I like the red one—looks all rusty.
          When you did your details,can you remember how many coats of filler primer you used over your tape lines?
          Pete
            Thanks Pete. To tell you
            Thanks Pete. To tell you the truth I don't remember. But 6-8 coats ought to do it. Then sand lightly and peal the tape off. Sand again and your done.
            Steve
            • pirate
              • 849
              So you sand again after
              So you sand again after removing the tape?
              I guess that would get rid of the rise of paint at every piece of tape I got on my test piece.
              So will the lines still be there?
                Pete yes they will. If
                Pete yes they will. If you make them deep enough and sand carefully you will get rid of the raised area at the tape. Yes do a couple of tests. It gets better each time you try. You'll get a feel for it and your ready to go.
                I believe they make the tape down smaller than 1/32. That's what I used because I had it on hand.
                Steve
                  Do you know of an
                  Do you know of an online supplier for that tape, Steve?
                  I was going to scribe my weld lines in, but the tape method looks quicker and easier, and it certainly looks the part.
                    Andy I lost the link
                    Andy I lost the link to the place that is here in Santa Monica CA. I got it from Adam and yes you can order it on line. Try a search for chart tape and let me know what you come up with. I'm just about out of the stuff myself.
                    Steve
                      Got the boat wet today.
                      Got the boat wet today. I bathroom trimmed it yesterday and did more today. But I need to do a hair more. Cut back on the pitch throws and I got a smooth running boat.
                      BigDave's WTC worked like a charm. No leaks. No problems and as you'll see in the video(which is real time) I lose signal and she went down about 9 ft to the bottom. The fail safe blew the ballast and even with such pressure at that depth the bladder filled and she got back to the surface. She has plenty of power and turns very tightly in my pool. What a nice change. This boat could really use an APC. But the more I drove it I became accustomed to it.
                      Unfortunately it was very dark outside and it rained before I could show it on the surface. Didn't want to get my surface camera wet and the wife didn't like the idea of doing video in the rain.
                      I trimmed the boat so the very top of the sail touched the surface. Another safety. But once she gets real deep pressure changes the game again as is evident by her going to the bottom with an empty bladder.
                      I was very pleased with the boat for a first run.
                      Steve
                      http://s94.photobucket.com/albums/l114/ ... nagain.flv
                        Great looking boat! I'll bet
                        Great looking boat! I'll bet she maneuvers well with that X-tail.
                        re: tape - I use ChartPak for the same type of use in creating hull plate lines, etc.
                          Thanks Jeff! Yes she does.
                          Thanks Jeff! Yes she does. And yes the tape works great specially for those old German boats. You can even stagger the tape to look like uneven weld lines and enamel over them.
                          Steve
                          • pirate
                            • 849
                            Andy,
                            I'll post the link where
                            Andy,
                            I'll post the link where I found mine for all to see, but it's on my computer at work. I'm using 1/64".
                            Pete
                            • lobo
                              • Jan 2006
                              • 48
                              Steve,
                              Another masterpiece...although your GW
                              Steve,
                              Another masterpiece...although your GW kit will always be a cult favorite of mine
                              Any plans on reissuing previous kits or new ones down the line?
                              Today I spent some time trimming out my GW. Trying hard to get it all done & running before I close my pool...but here in NY leaves are just beginning fall..not much time left!
                              I would like to install a fail safe in my GW. Can you (or BD if he is reading) give me any particulars on device used & hookup to the RCABS WTC we are using?
                              Thanks
                              Steve NYC
