Does anyone have photos of it? I have a half accurized kit. This is cos the photos i have leave a small amount to be desired. (THEY ARE CRAP.)
And along with my about to start Permit conversion i would love to crack into this kit again.
Hi Oscar, sorry I've never seen any clear pics of the Seaquest! Even in the TV show it was normally very dimly lit. (One of the eventual turn-offs for me).
I have seen plastic model kits of the Seaquest. How accurate they are - who could say for sure? but they look right to me. Usually thes kits have line drawings at the back for painting guides and decal application.
If not I'd make my own drawings taken from the model and then enlarge them up. You might find you are the first to have a set of workable plans for the Seaquest. Then people might come nocking on your door for a copy.
Hope you don't give up on the project. It will be a most unusual model to own.
there was a post long time ago on the sub-pirate page about a fellow, who built a large sea-quest model.. about 8ft or so...
do a search over there..
good luck
You could also do a search here. Check out the thread on page 4 of this section. I'm not sure what happened but the pictures don't show. I have copies of the pictures of the boat and it's impressive to say the least. I'll post a couple if you want to see it. As for the size It's very heavilyy towards the "or so".
Don
The SeaQuest DVDs are great for extra pictures. The season 2 DVD just came out, and while I've only seen the first few episodes, it has a bunch of great shots of the seaQuest, as well as a few surfaced shots, which is helpful for figuring out its true color scheme.
The model pictured above was built by Andy Cox. He was a professional pattern maker/model builder, and I think it shows in the quality of his work.
He used the Monogram model as a reference. At the time this was the best reference on offer, as Amblin were in no mood to cooperate. I believe the correct shape should be a little more 'rakish' especially in the area of the bow.
All the same, this model is instantly recognisable, and a solid piece of work.
The model was built back in the early nineties, and then got mothballed for many years whilst Andy concentrated on career changes, moving house, raising a family etc.
I believe he is back working on the project, so maybe we'll see the leviathan working soon.
Andy did once intend to kit this hull, but the cost was high, and you'd have to be a very serious enthusiast to want to own one. I believe a figure of £2000 ($4000) was lofted about, and that was some years back.
$4K is reasonable, at least in my estimation. The CR Nautilus is $1500, and way less than half the size of that beast! Depending on where I was in life when the kit went into production, I'd seriously consider it!
Of course, then you'd need a trailer to haul that beastie to the pond, and probably another $2K in electronics, pumps, radio gear, etc to operate it....
Hmm... on second thought I shudder to think what my wife would do to me if I brought that thing home...
Be warned, building a CNC machine is no simple option for making your boat.
I've been building a small CNC mill for about 6 months now. The learning curve is akin to being pushed over a cliff!
Personally for such a project, I'd build by hand.
Looking at the Seaquest, it really is a model that needs to be treated as three or four hull sub sections, and that is the way I would build it.
I would also consider using very traditional boatbuilding methods to create the main sections i.e. use wood and either bread and butter laminations or plank-on-frame.
You can use a premade spehere for the centre section.
