I am just starting to build my Engel Lafayette. The two hull halfs have an excellent internally glassed in strip bonding them together. I have some pin hole leaks near the bow. The joint between the two halfs is so tight that nothing I have will infiltrate the pin holes. Should I use my Dremel to slightly open the exterior of the seam enough to be able to get a filler in? They suggest a two part filler, but what I have is too thick. May I please have suggestions.
Thank you,
John Maguire
Seattle
Thank you,
John Maguire
Seattle
