Trumpter Seawolf
  • wayne frey
    • Aug 2003
    • 925
    #76
    It will be the next
    It will be the next logical step the Russians should take in evolution of their boats.
    While I like the little Alfa, it's day has passed.This will be a 21st century , worry-about-it out-there somewhere , boat.
    • redboat219
      • Jan 2005
      • 523
      #77
      maybe an Alfa, it is
      maybe an Alfa, it is the fastest sub in the world, given to that stupid liquid magnesium reactor.
      Subcaptian,
      AFAIK Alfas used Lead-Bismuth Alloy Cooled Fast Reactors not Magnesium.
      redboat
      • Rogue Sub
        • Jul 2006
        • 1724
        #78
        Magnesium reactors would make an
        Magnesium reactors would make an awesome last start up!
        • redboat219
          • Jan 2005
          • 523
          #79
          makes one helluva flare http://www.subcommittee.com/forum/icon_biggrin.gif
          makes one helluva flare enough to reduce the sub to a molten puddle of slag!
          • wayne frey
            • Aug 2003
            • 925
            #80
            Looks like this will go
            Looks like this will go to a supplemental thread on repairs.
            I tried to reassemble the pump jet shroud base. After getting it close, I realized it was just not going to be the same no matter how I willed it.
            The answer is clear. I reordered another pumpjet to replace the damaged one.
            I used the dremel to remove the base, and filed the stern back for the new shroud. I also discovered the front lower lip was cracked, so I removed that also. Found a crack in the lower part of the hull to be repaired. This is turning into a deal!!!
            Screw shown to show paint gone where it was bent badly before.
            • Rogue Sub
              • Jul 2006
              • 1724
              #81
              What is that last shot
              What is that last shot wayne... a look how many pump jets I have that dont fit my seawolf picture?
              • wayne frey
                • Aug 2003
                • 925
                #82
                For scale, and yes, to
                For scale, and yes, to see who is paying attention.
                This all comes into play as my path is now clear for the next two years. But, the subject at hand is not neglected.
                • Rogue Sub
                  • Jul 2006
                  • 1724
                  #83
                  So, why dont you just
                  So, why dont you just go ahead and spill the beans! I know your doing the Akula which will be fun because I got another one so I can redo it better this time. The other projects your hiding is to diff to determine. The reason for about 4 large PJs though is boggling.
                  • wayne frey
                    • Aug 2003
                    • 925
                    #84
                    What the heck is Wayne
                    What the heck is Wayne been doing????
                    Hanging out in the Heart Hospital of Houston(4 times in 90 days). But, I am still here, darn it!! Ha!! There are a few outside things going on that have slowed me down also. But, fans, while we waited, the screw got straighten,trued,resanded, and repainted.
                    The old pump jet base was gradually cut away, and resanded the stern down to pre-install condition.
                    I then slid the ouput shaft through the bearing in the hull, to insure alingment, and free turning (especially since the bearing is already fixed).
                    Using the bearing as a guide, I CAed the new pumpjet on.
                    I did, of course, clean up the inside of the new pump jet with files, and evercoated any irregularities and smoothed out. Why? For lower acoustical signature, of course!!!
                    • wayne frey
                      • Aug 2003
                      • 925
                      #85
                      Done.
                      Patrol ready.
                      http://www.postimage.org/gxm5W1J.jpg
                      http://www.postimage.org/gxm6010.jpg
                      http://www.postimage.org/PqEV5o9.jpg
                      http://www.postimage.org/gxm650i.jpg
                      http://www.postimage.org/gxm67vr.jpg
                      http://www.postimage.org/aVF2hS9.jpg
                      Done.
                      Patrol ready.
                      That will do pig, that will do...
                      • pirate
                        • 849
                        #86
                        Wayne,
                        I may be mistaken in
                        Wayne,
                        I may be mistaken in what I'm seeing in these pictures, but I'd appreciate it if you didn't put my pumpjet assembly on someone else's Seawolf kit.
                        Pete
                        • redboat219
                          • Jan 2005
                          • 523
                          #87
                          I don't think Wayne's using
                          I don't think Wayne's using your PJs. The one he has on looks appropriate for 1/144 and not 1/96 scale. I think he's just using it for comparison...
                          • wayne frey
                            • Aug 2003
                            • 925
                            #88
                            Pete,
                            That is the Trumpetor
                            Pete,
                            That is the Trumpetor Seawolf in 144. It is a Caswell Pumpjet. Which, for that model is the best to have. It looks very scale.
                            The pumpjets I got from you are going on the classified projects I told you about You already know where the 3 are going,remember? (and you are sworn to secrecy).
                            I actually consider that a compliment, Pete. Your Seawolf in 1/96 is the best current production avalible in that scale. For my little park runner 1/44 to pass as accurate enough to even momentarily make you think it might be yours tells me it must look ok I am pleased with the project
                            While my build went with the reverse RCAB, which intrigues the heck out of me, Caswell's fittings kit to upgrade/enhance the Trumpetor kit are excellent quality. Credit given where due.
                            Now that this one is done, I have something to run with the Subron 5 guys while I have the REAL project again , working in drydock.
                            • xxl
                              • Jul 2008
                              • 79
                              #89
                              looks like a great boat
                              looks like a great boat hope you enjoy it mine kinda went south i think i got in over my head
                              • kazzer
                                Banned
                                • Oct 2006
                                • 324
                                #90
                                Pete,
                                Pete,
                                Not mine, I only sell them. Merriman (D&E Miniatures) is the designer/manufacturer.
