Andy,
You know that 3/4"
Andy,
You know that 3/4" sounds like a good distance if you are moving batteries around. Of course if we use half the weight it will have to move twice as far. etc. So much to play with so little time.
I am really glad you mentioned the metacentric height. It's one of those terms you just need to know when dealing with anything that floats. But I have been to toung tied to mention it and describe what it is. For those that are curious check out http://en.wikipedia.org/wiki/Metacentric_height
Sorry it does not talk about submarines specifically. Such is life when 99.9% of water craft are confined to the surface. Still the link is to Wikipedia. Maybe we could edit the nice picture and put a torpedo in it. That should get some notice...
That is an excellent suggestion to disable the pitch control when under way. That's when the dive planes come into their own. I shall make sure it gets into my plans.
Bob, Andy you have inspired me. As soon as I finish this post, then do my day job that spills into my night, I will get some numbers on how slow that lead screw is... I really like the idea of fixing the ballast tank and putting a lead weight on the leadscrew. Having a servo would be the ultimate in simplfication. Out with the APC and 12V motor.
But curiosity has me and I am going to see how the system behaves with the moving ballast tank first. Maybe that way I can actually say "did it both ways, and this was better".
Neil,
It's funny you mention the pump idea. I was interesting in that too and found a post that mentioned a 12v fuel pump ( http://www.ripmax.com/item.asp?itemid=L ... tegory=080 ). I tried to get one to play with, but could not get a distributor that would talk to me
The other thing to think about is you may not reallly need two tanks. If you had one tank at the front that kept the model level when it was 1/2 full then you could pump water in to drop the nose, and take water out to lift it. BUT this would probably need you to have the air in the one tank at pressure. Two tanks sounds much easier if you have space.
I do tend to agree with Andy that it could be more difficult to get this to work accurately. I suppose you could move the tanks closer to the center of the hull so you need to move more water to have the same effect. Still I think it is in-herently less accurate than a lead screw. I don't know the size of hull you are thinking about but I'm guessing that you would need a fair amount of real estate for the two tanks and a pump.
Nuke!
This is my second week on the message board. I have been jealous because everyone has their own little message beneath each post and I could not think of anything... But now I know I wish to be known as the "over engineer" in your / our honor
Please don't expect daily updates. Most of the time I am a weekend (and every idle thought during the week) modeller.
But today I do have a little thing to add. Time to upload some more pictures...
You know that 3/4"
Andy,
Neil,
Nuke!
