Well you may remember earlier
Well you may remember earlier in the post I lost my concentration while drilling the hole for the stuffing box (that the prop shaft will live in). Time to fix that little error.
This time I started earlier in the evening and ensures I had a fresh cup of coffee... Must get alignment right... What to do.
That's right. Anytime you want to pay extra-ordinary care aligning things you build a jig. This was just a piece of scrap plywood. I cut two grooves (for the hull sides) 6" apart. Then I drilled a 3/16" hole at the mid point. This gave me alignment side to side, and since the centerline of the hole was aligned to the top of the grooves top to bottom.
I was determined not to goof on this again.
Looking carefully at the tail you can see the washer between the prop and the stuffing box. It needs to be there, but I don't want the prop that far away from the hull. So I recessed the stuffing box into the hull 1/2 the thickness of the washer. I had to file the resin around the stuffing box also to allow the washer to sit into the hull.
At this point the plywood jig was holding one end of the shaft true, and I used the prop to ensure the tail end of the stuffing box was in the right location. Then I carefully removed the prop and applied a drop of CA to hold the shaft in place.
Then I checked the alignment and it was all good. On to the next phase.
I applied packing tape to the end of the sub, making sure the stuffing box was sealed. The the hull was stood up on it's tail so I could pour resin into the enlarged hole that I created earlier. I put tape over everything that I might spill resin on by mistake.
The front / top end of the shaft is still in the plywood jig.
Then it was left overnight to harden up.
The shaft was fixed in place. The resin did not seep all the way down to bottom of the stuffing box hole so I used CA to fill the void. Then I took some files and removed the resin / CA from around the tail of the shaft to give me the space for that washer recess.
While the shaft was setting up the night before I took the time to glue in collets to the flaps for the rudder & dive plans.
As you may recall there is a brass tube running the length of the flaps. This tube will align with the tube in the fins. On each flap I had drilled out a hole deep enough to recess a collet into the fin. So now was the time to glue.
I had a nice slow setting waterproof epoxy. Before applying it I made sure I had 4 spare peices of 1/8" rod. I would use these to ensure the collet aligns with the tube inside the flap. I also sanded the end of the collet and filed grooves into the edge of the collets. This would give the expoxy something solid to hold on to.
The glueing was relatively un-eventfull. I started out with the brass rods in place for alignment. I was worried that if I left them they would be glued in permanently. So I popped them out, cleaned off any glue, and then every couple of minutes I would just check that the collets were still aligned with the tubes. All looked good.
If I found the collets were floating around and needed to have the rod in place to ensure alignment I had a plan B. I was ready to apply a layer of vaseline to the rod. I hoped this would prevent any bond forming with the alignment rods. But thankfully plan A worked.
So the next day it's assembly time.
While I have easy access the push rods are attached to the shafts that go through the flaps. Note the "extended" allen key wrapped in green tape. I could not reach that far without it.
That's the shaft support. The stuffing box lives in the center. You can see the vertical shaft that is the secondary control rod for the rudders, and the horizontal one for the dive planes.
And here it is installed. Now we have flaps that work as they should...
And we are looking more and more like those plans on the wall...
But oops. Man's best friend thinks I should pay more attention to other things, like his favorite pink tennis ball...
