OTW Type XXIII questions
  • delphin
    • Sep 2005
    • 25
    I came across a lower section for a OTW Type XXIII and need a little help. I am going to try to lay up the upper hull and sail. What is the measurement from where the upper and lower hull splits to the top of the hull?
    What are the measurement for the to the top of the sail and the sail length?
    I think the lower section I found is 1/24th scale.
    Thanks in advance.
    Re: OTW Type XXIII questions
    Thanks in advance.
    you have a heck of a task ahead of you.
    before you begin that, why don't you check with Bob Dimmack (otwdes@msn.com) and see if he can cast you up an upper hull, or if he has a "second" that you could buy and then cleanup...
    If you insist on doing it yourself, I'll pull some measurements for you.
    let me know...
    Sam
    • delphin
      • Sep 2005
      • 25
      Sam,
      Thanks for the reply. Can
      Sam,
      Thanks for the reply. Can you pull some measurements for me?
      Thanks.
        It may be a few
        It may be a few days...got a busy weekend coming up.
