Stern Plane Info!
    Stern Plane Info!
    Morning campers!!
    I just wanted to pass on some info I have found out from running my Gato. There was talk a while back about the kit showing the stern planes mounted upside down from the real boat. While this looks like it is true, I can state for a fact that the airfoil shape of the plane does affect the running boat. The faster I go the more it sucks down the rear end. Crazy Ivan has experienced the same effect. I would suggest if you do not want to deal with this problem to either sand them symmetrical or add more material to the other side to accomplish the same result. I plan to try and correct mine, but being on the boat it will not be as easy. For you guys that have to have (dead-nuts) scale please disregard this message and build it what ever way you desire. BD.
  • landlubber
    • Nov 2004
    • 60
    Hi Dave.Hows the snow business
    Hi Dave.Hows the snow business in NY.Its great in Ont.
    Say can you perform a mixing functtion with your new radio that mixes the throttle position and the dive plan position as you throttle up. I have done this with rc planes in the past.
    Just a thought.. regards Kent.
      Hi Kent,
      Yes I can
      Hi Kent,
      Yes I can do that and did, but I still did not like the way it responded. I would like to eliminate the problem at the source. I did not think they would have as much effect as they do. BD.
      • tabledancer
        • Feb 2005
        • 573
        Dave,
        I havn`t set anything in
        Dave,
        I havn`t set anything in stone yet.Could I swap sides and install them upside down and get the affect of keeping the stern up and not having the "lowrider look"
        TD
        • landlubber
          • Nov 2004
          • 60
          I was pretty sure you
          I was pretty sure you would have tried that. Hey if you flip them and put enough power to it maybe you can get it to fly. hahaha.
            I don't see why not
            I don't see why not TD.
            Give it a try and let us know. I was told the bow design of this type of sub has a tendency to lift as it cuts through the water. Maybe this was to compensate for the lift.
            Hey Kent!! I already have a Hydrofoil. Ha!! BD
            • tabledancer
              • Feb 2005
              • 573
              With my setup they can
              With my setup they can go either way,but I can`t say when it will be ready for the first seatrials But the water is way to hard now to drive it anywhere.
              TD
