USS Seawolf (SSN21): Mission Alpha
  • danl
    • Oct 2006
    • 39
    SSN21 Sea Trial Report, 12 Nov 2006, Edina, MN
    15:30 hrs: Seawolf leaves port for first sea trials under command of Captain DanL and TMSmalley, Chief Technical Officer.
    Still in primer, the boat is fully fit for cautious first run, with basic systems operational except sail, periscope system and cheater rudder (left on the workbench). Initial trim and buoyancy seem almost perfect.
    15:50 hrs: A speed run and first dive are completed. Modified Dave W. propulsor provides excellent speed forward and astern.
    16:20 hrs: Under a heavy overcast and rapidly approaching sunset, all systems perform well except rudder response. The initial plan to hug the shoreline yields to poor judgement and an attempt is made at a wide sweeping turn out in open water. The first signs of trouble are an erratic rudder and intermittent propulsor response. Could it be the brand new Polk Tracker III com system or antenna placement. No way - it’s a first-class digital state-of-the-art electronic marvel. Attempts to steer to shore get no response. Then the red primed bow begins to rise slowly from the water, as the dark gray stern blends into the murky surface. On board, only the worst could be happening.
    16:30 hrs: The initial e-team assessment: The stern compartment is flooding, disabling the main drive and stern control systems. Darn, should have used bellows! In minutes, the bow is pointing skyward as the gray (someday) lady slips below the surface. Shoreline rescue equipment is inadequate to deal with the distance out to sea, the extreme 1,440 ft. depth and frigid 40 degree northern waters. An emergency plan is put into action – call in the divers for a search and recovery mission.
    But the late year sun is fading fast at the northern latitudes, and a 40 minute trip to assemble dive gear doesn’t help on the now critical mission timeline. Neither does the fact that the much needed powerful HID dive light system is useless without charged batteries (How many chargers do I own?)
    17:10 hrs: A sole Navy diver, with full ground technical support from TMSmalley, slips into the dark water under a black sky with only a really sissy looking lime-green flashlight, totally inadequate to search the murky depths.
    17:30 hrs: The search is called. Although the last location was well observed, the inadequate lighting in the black night-time sea makes further efforts useless until daylight. A disappointed DanL returns to shore, hoping mission Alpha doesn’t become Mission Omega.
    The saga will continue, hopefully happily...
  • jeffrey j
    • Apr 2004
    • 398
    Ouch Dan,
    Is that near the Baltic Sea where the "Parade of Model Boats" is held? I have sailed these waters. With the DSRV skipper Catp. Tim Smalley on the rescue, all should turn out well. Capt. Smalley knows how to recovery a submarine, life support systems should hold out for several days on a modern nuke, unless crush depth has been exceeded. Good luck, Jeff Jones
    • mylo
      • 723
      Dan,
      Great post. http://www.subcommittee.com/forum/icon_smile.gif
      Mylo.
      Dan,
      Great post.
      Mylo.
        I guess you have not
        I guess you have not discounted the fact that terrorist insurgents may be behind this!
        • shadowpeo
          • 82
          Re: USS Seawolf (SSN21): Mission Alpha
          now that I am guessing is "scale" depth, what is the actual water depth in the area
          Edit: assuming a 1/96 scale conversion the sub is in ~15 Feet of water correct??
          • danl
            • Oct 2006
            • 39
            Depth
            It's a 1/144 Trumpeter plastic kit conversion. Depth is about 10-12ft.
            Wish me luck today - it's 33 degF (0 degC) and heavily overcast.
              Good luck Dan!
              My Seawolf
              Good luck Dan!
              My Seawolf sank at the Lake Redman regatta from a broken battery connection. They found it 12 feet behind the point where it sank in about 6 feet of water. The current had carried it backwards of the direction it was headed. I am sure you will find it. BD.
              • hakkikt
                • 246
                Luck to you, Dan.
                Been lurking
                Luck to you, Dan.
                Been lurking around your thread from the beginning, catching useful info & inspiration for my own Trumpeter Seawolf kit, which sits on the workbench and waits to be turned into my first RC boat.
                3-4m of water depth and low water temperature sounds like visibility should be good enough to find it. Wise of you to choose red & white primer instead of dark gray.
                • danl
                  • Oct 2006
                  • 39
                  SSN21 Sea Trial Report, 13
                  SSN21 Sea Trial Report, 13 Nov 2006, Edina, MN
                  1400 hrs: Surface recovery vessel USS Fishnet approaches last sighting co-ordinates in calm seas with bright sun and balmy 40degF temperature.
                  Seawolf immediately located and easily retrieved from only a little over 1000ft. Bow straight up and propulsor buried in 36ft of seabottom.
                  1630 hrs: Seawolf in drydock. Aft WTC flooded approx. 50%. Mid and forward WTC's dry, although light condensation in both. Causes of accident: New brass gearshaft slipped forward, away from driveshaft coupling, probably allowing some leakage around shaft seal and loss of full drive engagement. Primary cause of leak was a hollow control linkage tube used instead of solid rod. Although the inside end was sealed by a rod insert, the rod pulled from the shaft, allowing water access. Both details easily resolvable and easily preventable. Details will be covered in following reports.
                  Immediate Action: All tubes and components disassembled. Wet damp components rinsed and scrubbed with 91% isopropyl alcohol. Blue-green terminal corrosion scrubbed off with alcohol and toothbrush. All components then placed in airtight dehydration chamber (uh - Tupperware with lots of dessicant packs). Minimum 48 hrs in dessicant before any power-ups or electrical testing.
                  Damage Assessment: Will likely replace both mini-servos and the drive motor. Cost estimate (scale factor 144 cubed): $75MM
                  1700 hrs: TMSmalley promoted to Supreme Subcommittee Commander for oustanding moral support in time of crisis (hey! let me get a picture...)
                  Capt. DanL loses sea command and assigned to Seawolf repair program and accident analysis. The expected promotion to a Thor class boat in January is cancelled (ouch! gotta call Lyle...) until competency demonstrated on Seawolf refit and eventual open water operation.
                  1940 hrs: Think I'll check the battery voltage...and start planning for Mission Beta. Isn't this great fun?
                  • bcliffe
                    • 337
                    Dan,
                    Glad to hear you had
                    Dan,
                    Glad to hear you had a successful recovery. Good luck correcting root cause, and get back out there ...
                    Cheers
                    BC
