What to expect...conversion cost Type VIIc sub
  • mike.h
    • Sep 2006
    • 2
    Thinking of doing a Revell Type VII C 1/72 conversion for r/c.
    What kind of total expense (minus the cost of the model itself)can I expect by the time its done? Thanks.
    Depends how much of the
    Depends how much of the work you are prepared to do yourself.
    If you want a kit then here are two options-
    Add about $150 for RC, batteries and motors etc.
    • tabledancer
      • Feb 2005
      • 573
      Including the sub kit and
      Including the sub kit and the radio"AirTronics 6 ch" Big Daves WTC,and a few brass goodies I have about $1,100 and change in mine.But don`t you dare tell my wife.
      TD
      • tabledancer
        • Feb 2005
        • 573
        Also like they say,"If you
        Also like they say,"If you want to play with the big dogs it costs money,if not stay on the porch"
        TD
        • libor
          • May 2005
          • 106
          Another possibility with a RC
          Another possibility with a RC kit]Type VII conversion[/url]
          JOG 1-2
          • chuck chesney
            • Mar 2005
            • 176
            I am astomisihed by the
            I am astomisihed by the numbers being thrown around regarding the cost of converting the Revell kit. I've been running subs since the late 1970's, and if you shop prudently, and do a lot of the work for yourself, rather than buying it "ready made", you should be able to do it for about three hundred bucks, box to water. It doesn't cost an arm and a leg to build a plastic model kit, and make it run and dive. You don't need a machine shop or a radio system that can control the space shuttle, you can do it for a lot less money and effort, with equal results. This isn't brain surgery, it's just a hobby.
              Let's see... I think I've
              [color=#000080]Let's see... I think I've got most of the guts for mine]
                Radio]
                I won't argue the point
                [quote]Radio]
                I won't argue the point on the other items, but I know those items can be purchased for a lot less, especially now.
                A TX can be had for under £25, a receiver for about a tenner, so that's £35 for the radio ($70). Micro servos are now under a fiver each, and small motors are very cheap to source (surplus buhlers are nice), I'd say £15 would have it all covered ($30).
                ESC's are really cheap if you know where to look. I'd say £20-30 with failsafe ($60).
                Good li-pos can be had for under a tenner.
                Edited By Sub culture on 1158261944
                  A legal surface freq. radio
                  A legal surface freq. radio with at least 4 channels? Not a new one for that price! a Polk 6 channel is $188.00 and there is not much else to pick from. The car radios only have 2 channels & the rest are a/c freq.
                  • davietait
                    • 135
                    I've just bought a 4
                    I've just bought a 4 channel Hitec Flash 40mHz off Ebay for £58 inc shipping ( about $110 ) only thing I need for it is a 4 channel reciever as the original one got soaked and packed up and i'm getting a 3 channel one with the TX ( which is fine by me as i've got a Hitec Ranger 2 3 channel 40mhz Tx already for my R/C surface models - or targets ).
                    I have looked around Ebay and can get the Revel 1/72nd VIIc ( and VIIc/41 ) for about £45 delivered ( $90 roughly ) and the Lexal pipes for building your own WTC's are not very expensive ( about £14 per meter in 38mm,50mm & 70mm O/D by 3mm thick + shipping ) as you could buy 3 different sizes and get 3 or 4 WTC's out of the pipes. As for cap ends , looks like i'll be trying to get a mate of mine at the local college to turn mine on their lathe's which are CNC thank feck.
                    It can be done cheaply , BUT , i'm considering ordering BigDaves WTC for the Seawolf kit i've got just so I can see how thats done to give me insight before designing my own one.
                    Davie
                    Edited By DavieTait on 1158269068
                    • tabledancer
                      • Feb 2005
                      • 573
                      I spent a little more
                      I spent a little more than Bob for my radio,a lot more for the battery"lit/ion" and charger,paid for my ECS,Subsafe,and airpump for the ballast system.And I paid more for the sub kit than he did,the brass props and shafts were more expensive,in addition to the u-joint kit and the brass deck and detailing kit for the hull have to be included.Ithink that what I spent for my boat was not that far out of line as some people tend to think.I don`t have all the resources available to me as some people,so I have to pay a little more,no big thing.
                      TD
                      • colin-stevens
                        • May 2006
                        • 10
                        Dave, as you may have
                        Dave, as you may have noticed, me seehund leaks, servos wet more often than not, also the receiver. open them up, let them dry and i have had no problem.
                        may be teeching you to suck eggs but put the receiver in a balloon, cable tie the end, twice, and problem soved, get it as wet as you like.
                        also Maplin do a cleaner for electronics, also helps.
                        colin
                        • stark
                          • 243
                          I would say go with
                          I would say go with the Polk 8 channel , it's the last Radio you will need to buy !
                          Brian
                          • davietait
                            • 135
                            Unless the Polk 8 can
                            Unless the Polk 8 can use 27Mhz AM or 40Mhz AM or FM then we can't use it over in the UK. Sucks being over here sometimes I can tell you !!
                            Davie
                              It's available in 75Mhz, 72Mhz,
                              It's available in 75Mhz, 72Mhz, 40MHz, and 35MHz......
                              A lot of folks swear by them.
