water proof servo
  • georget
    • Mar 2004
    • 74
    water proof servo
    What is the best way to water proof a servo? Or does someone make an enclosure for a single servo only?
    George
    I'd make an enclosure.
    Very simple-
    Very simple- just cut a short length of small drainpipe, and four discs from sheet plastic.
    Make two of the discs equal to the inside diameter of the pipe, and the other two equal to the outside diameter.
    Glue the smaller discs to the larger discs- these will form simple stepped endcaps.
    Make a frame for the servo to mount in. Place inside the small pipe.
    Seal the endcaps to the pipe with silicone sealant.
    Goes without saying you'll need to drill holes for your servo lead and pushrod seal/bellows.
    • fung pang
      • 91
      like this,
      http://home.att.net/~cheap-sub/servo_wtc3.jpg
      and
      servo wtc
      like this,
      and
      servo wtc
