Dear all,
I've just completed my new WTC and don't use a speed controller. (Bit expensive)
I've designed a "Switchplate" It comprises a servo with the two horns attached to the motor contacts. These horns alternate between two sets of contacts on a plate to either run the motor forward of reverse. You can probably visualise it. Simple . Problem is it's the only servo that twitches. The switchplate works well but the twitching is just annoying me...
Is there interference caused by a current going through the switchplate.
Any electronics guru's out there with ideas?
regards.
David H
regards.
David H
