Battery Poll - What Batteries do you use
  • smwarships
    • 104
    Hello Group,
    1) What battery do you use?
    2) Where do you buy your batteries?
    Thank you for your time and help,
    Darle
    Edited By smwarships on 1148608137
  • warpatroller
    • Feb 2006
    • 308
    Try this place]http://www.thomas-distributing.com/index.htm
    I've bought the
    Try this place]http://www.thomas-distributing.com/index.htm[/url]
    I've bought the Maha 2500mAh AA's from them, they seem to be pretty good, though I haven't tried them in a sub model.
    You will find Maha 2700s and 2900s from another brand on the same site.
    • tsenecal
      I use, or have used
      I use, or have used the following]http://www.cheapbatterypacks.com[/url]
        I use standard NiMH AA
        [color=#000000]I use standard NiMH AA with "decent" capacity (>2000 mAH)
        I buy them anywhere I see them advertized, but I try to get
        brand names (like varta, panasonic etc.)
        I build small models, with small motors.
        runtimes ]
          I use, Lipos were space
          I use, Lipos were space is tight, Lead acid when it isn't and need to add ballast and NIMH for everything else. AA cells cant supply large currents like C cells so a only suitable for lower Amp draw motors.
          • libor
            • May 2005
            • 106
            Hi,
            I am going to use
            Hi,
            I am going to use NiMH "D" type batteries from GP with 8750 mAh capacity bought from local vendor. I do not solder them, but use this]http://www.subcommittee.com/forum/IMG_4317.JPG[/img]
            Libor
            • tabledancer
              • Feb 2005
              • 573
              I use a Duralite Plus
              I use a Duralite Plus Lithium-ion 7.4 volt 950 MA riding wet in my ROG conversion.Expensive little bugger but does a good job.Bought it from a local R/C shop.
              TD
                I use NiMH cells purchased
                I use NiMH cells purchased from Batteries America, I buy whichever sized cells best fit the needs of each sub and make up my own battery packs. My 'favorite' pack is a 12volt 4Ah pack that I made from 10 4/3rds sized AA cells....that pack allows me to run something like an OTW Type VII or Seehund around 3 hours.
                  Try http://www.batteryspace.com/
                  They have very good
                  They have very good deals. BD.
                  • lobo
                    • Jan 2006
                    • 48
                    NiMh 3000 Sub-C's in my
                    NiMh 3000 Sub-C's in my Engel lafayette! (20 of them in 4 packs)!
                    I by batteries here]http://www.all-battery.com/index.a....gory=39[/url]
                    • silent runner
                      • Jun 2005
                      • 188
                      For my NiMH packs, I
                      For my NiMH packs, I order from www.maxamps.com, here in Oregon. Great prices and will build any configuration/ah required. I buy my gelcells form All Electronics, very reasonable prices and you can't beat the flat rate shipping.
                      Mike
                      • smwarships
                        • 104
                        Hello Group,
                        Well I checked out
                        Hello Group,
                        Well I checked out all-battery.com and found a deal that I
                        couldn't pass up. Two 12 Volt battery packs and a charger
                        all for less than $70.00, that includes shipping cost.
                        They are having a sale right now so you might want to
                        visit them if you may need ro do need batteries.
                        http://www.all-battery.com/index.a....dID=898
                        Darle
                        • lobo
                          • Jan 2006
                          • 48
                          Hello Group,
                          Well I checked out
                          Hello Group,
                          Darle
                          Well,
                          I am very happy my suggestion was able to help out, You are very welcome!
                          • smwarships
                            • 104
                            Hi Lobo,
                            Thank you for the
                            Hi Lobo,
                            Thank you for the information, it was a big help. In fact they
                            have the best deal that I was able to find. I did find a deal
                            on some Panisonic batteries that had 4000 mah,however they
                            wanted $60.00 for 10 cells so I had to pass on the deal.
                            Thank you for your help,
                            Darle
