RCABS custom bladder
  • adriaticsea
    • Jun 2003
    • 139
    Hi everyone,
    Art, thanks for the
    Hi everyone,
    Art, thanks for the explanation. From what I see, tee fittings are NOT valves, just a way of distributing the air flow. If you use it to connect the bladder to the pump and the air release, I assume that the pump itself is airtight and acts as a air stop until you release the air with the schrader valve. Correct? (I'm using 6V Oken pumps).
    Thanks,
    BEST REGARDS MAURO
      Mauro,
      Your assumption is correct, for
      Mauro,
      Your assumption is correct, for all practical purposes. The Oken pumps have an average leakage of about .4 mmHg/minute, which does not cause any problem during the normal running times of model subs.
      Edited By Art Broder on 1148383171
      • adriaticsea
        • Jun 2003
        • 139
        Hi Art,
        thanks for the quick
        [color=#000000]Hi Art,
        thanks for the quick and accurate response. The excellent airtightness of the Oken pumps is a great thing and simplifes a real lot the making of my custom bladders. I'll use a four-way fitting (one end glued to the WTC endcap, the other three hanging out) to connect all the bladders in the wet space of the sub and then I'll connect the main tube with the pump and the release vale using a tee connection. Simple and reliable, this way I'm not going to have to add another valve to the rubber bladders and this will minimize the risk of leaks.
        One last thing]
        Edited By AdriaticSea on 1148394488
          Yes, Mauro, I took the
          Yes, Mauro, I took the valve stem out of the valve body and CA'd a proper size brass tube into the remaining valve body to connect to the flexible tubing.
