Hi all, just as an inspiration, I would like to show you my
endcap in progress. I succeeded with ordinary tools, so
everybody can make endcaps !
I believe Fung Pang made endcaps the same way, but i'm not
sure.
I made an endcap from 4 disks of plexiglass (or lexan, dunno.).
These were drilled out with a large bore hole cutter (see link below)
Then three disks were stacked and bolted together.
The bolt was put into the drill, creating a poor man's lathe.
with a file and sandpaper, the three disks were made the right diameter. it fits perfectly in the PVC pipe that is my WTC body.
next steps are to sand the middle disk down a bit more, creating a groove for an O-ring.
then a fourth disk is added with a larger diameter and all is
glued together using 2-component cement.
I will think of a way to close the central hole in the disks.
cheap wtc construction
from now on, you have
- cheap plastic kits like the trumpeter Kilo for a hull
- a DIY wtc for a few bucks
- a DIY piston tank
- ordinary electronics to control it all
and the water tight linkages won't break the bank either.
Your wife will love it ! maybe now you can afford to feed your children instead of buying an Engel Typhoon
Edited By raalst on 1139081921
sure.
- a DIY piston tank
