Hi I am about to start the Revell kit with the help of the David Welsh WTC My question is what changes do I need to make to the plastic kit to make a working model?
Revell u boat - RC plastic convertion
Mark,
You should have gotten a
Mark,
You should have gotten a CD with your WTC kit. In it you will find an extensive write up on what to do along with alot of pictures. This is and excellent kit to work with. If by chance you have a question that wasn't answered on the CD you can contact Dave by e-mail, he is a very nice and helpful person.
Good luck with your kit and keep us updated as to how your doing.
BSF
Mark,
I started out by opening
Mark,
I started out by opening all the limber and ballast tank holes on the hull. Trust me that will keep you busy for a while. You could go ahead and build the conning tower.
You can also check out past posts in both R/C and static modeler to see what others have done.
Mark,
Don`t glue ANYTHING together yet,till
Mark,
Don`t glue ANYTHING together yet,till you get your kit from Dave.You must make some modifications to the hull internal supports and outer hull.
TD
