Battery / WTC - What battery type to use
  • thh
    • 15
    [color=#000000]Hi there,
    what kind of battery can i use outside of the wtc. How do I avoid to short-circuit when this battery is submerged.
    Thomas
  • silent hunter
    • 45
    I'm not an expert on
    I'm not an expert on this, but my good friend Romain Klassen in Victoria B.C. states that this is quite safe. He maintains that ALL his (u-boats) run w/ external batteries. Makes sense to me. We don't run these models in saltwater so there's not a problem with the conductivity,radio interference, or corrosion from the saltwater.
    You need to be able to utilize the biggest and best battery your boat can handle. The reason I say this is you need maximum runtime from your batteries If you need more guidance, please contact me here via the forum.
    Sincerely,
    Richard Frisch
    • wheels
      • 129
      Thomas......I would seal the positive
      Thomas......I would seal the positive terminal of the battery so you don’t corrode the terminal. Electrolysis will occur if you don't do this.
      Jim Wheeler
      • thh
        • 15
        ]My Webpage
        ]My Webpage[/url]
        • skip asay
          • 247
          Thomas -
          Basically, sealed lead acid
          Thomas -
          Basically, sealed lead acid (SLA) and gell cells are good as is. Just seal the positive terminal as Jim W. suggested. Everything else (Nicad/NiMH) needs needs more in the way of sealing since the cell cases are metal and not plastic as SLA batteries are. The heat shrink wrapping, by itself, is waterproof but it doesn't present a 100% coverage. It should be a relatively simple matter to seal around the heat shrink with silicone, though.
          Skip Asay/SubTech
          • thh
            • 15
            [color=#000000]]
            • britt boyette
              • 125
              Nicads work well in fresh
              Nicads work well in fresh water too. If you decide to use the old standby 7.2 Nicads, you must remove the shrinkwrap covering and dry off the batteries as soon as you remove the sub from the water. Use fiberglass packing tape to hold the cells together.
