Being new to rc submarines and scratch building a 1]http://www.subcommittee.com/forum/icon_smile.gif[/img]
So a couple of questions and no dout that i will have more questions as i progress along with this progect
and from what i have read on the forums so far. Is that if no one has done what you are asking that they will give there opinion on what u have asked
which is much appresiated.
and as for stupid or silly question as one of my sargents use to say "is that the only stupid or silly question is the ONE that you dont ASK."
first after reading some of the older posts i came accross one that talked about using the 900BB Grauper motor for the typhoon as they RPM are lower so i would not have to use a gear box. So i went searching for the motor and found a site that had a fair number of Grauper motors with the spec's. Here are the spec's for the two motors that looking suitable for the typhoon.
Motor Nominal Voltage Voltage
Speed 720 BB TORQUE 12v 6-13v
Speed 900 BB TORQUE 12v 6-40v
RangeNo-Load RPM NO-Load Current Current @ Max Effic.
4,100 0.75A 3.0A
6,500 1.1A 8A
Stalled Current Max Efficiency Case Length Case Diam
13.5A 75% 72mm 44.5mm
54A 71% 95mm 51.5mm
Free Shaft Length Shaft Diam Weight
6.5mm 5mm 380g
15mm 6mm 645g
from you experenced boat builders which one of these motors would suit the typhoon the best ?
am leaning towards the 720 BB motor
the second question from what i have read is that the WTC can get hot inside while the submarine is working, I was thinking of placing the motors in thier own WTC then soldering a wire to each motor then attaching it to a piece aluminum that i will be using as the keel. Am also trying to figure out how to use the aluminum as a heat sink for the rest of the electrical stuff in the boat as the aluminum will be sitting on the outside of the submarine. any advice on both question will be very helpfull.
thanks in advance
regards
Lee
(ps please forgive the spelling as i failed sellnipg at school lol)
Edited By gof on 1125151876
4,100 0.75A 3.0A
6,500 1.1A 8A
54A 71% 95mm 51.5mm
6.5mm 5mm 380g
15mm 6mm 645g
thanks in advance
regards
Lee
