Erratic Servos - Info request through website
    • 1367
    Just received this from the website]The following information was recevied on June 24, 2005:
    Email: Anduril_146@hotmail.com
    Phone]
    Any responses can be directed to Jeff through his email. THanks.
  • jdbostrom
    • Mar 2005
    • 135
    I have heard that putting
    I have heard that putting a thin sheet of metal between the servos can help remedy this problem. You would probably have to go a step further and ground the sheet too. Has anyone tried this?
    Jonathan
      if the problem is that
      [color=#000000]if the problem is that each single servo moves OK but both
      do not, then check the current requirements of the servo's
      and check that the BEC system (assuming you use BEC, i.e.
      single set of batteries for receiver as well as servo's) can
      deliver.
      Check if the servo's stall (too much friction, causing a LOT of
      current to flow), or are driven beyond their travel (essentially
      the same thing ]
      • drdave
        • 69
        Are you using a AM
        Are you using a AM band radio For the close quarters and better transient signal rejection A FM radio set up would work better . Installing resistors on the motor would be of help reducing noise as well Dr Dave
          DrDave, don't you mean capacitors
          DrDave, don't you mean capacitors across the motor ??
