Gents,
Prior post from JWLaRue
"Okay...now I'm a bit confused.
It's not clear to me how a ballast tank (RCABS or otherwise) is able to provide lift for a hull to get to the waterline when the ballast tank is at and above the waterline....at that point the portion above the waterline is just parasitic weight and not contributing to lifting the hull.
The analogy of a ballon sitting on top of the water is not a good one. The balloon sits on the "top" of the water because it takes very, very little of the internal (air) volume of the balloon to lift the weight of the balloon out of the water. In other words, I think it's a misleading analogy."-Jeff
Art here. The confusion here may be that the top of the WTC needs to be just below the waterline for the bladder on top of the WTC to provide lift to the correct waterline. Sorry it took so long for my response, but it took a while for me to get a picture to illustrate my correct balloon analogy. I hope you can see the bladder 2/3 to 3/4 of the way above the surface of the water, and still lifting the top of the weighted WTC almost up to the surface. The second picture is to show the deflated bladder and weighted WTC at the bottom of the pool, prior to inflation and surfacing.
Edited By Art Broder on 1118011215
