Launching Torpedeos
  • tabledancer
    • Feb 2005
    • 573
    Launching Torpedeos
    Last nite while working on my new boat I became inspired .Has anybody tried to fabricate a system to shoot torpedeos for the ROG 1/72 boat yet.Maybe it would be a stretch,because of space requirements,but I WAS JUST THINKING," could be dangerous"
    T.D.
  • boatbuilder1
    • 386
    dangerous?
    well if you think about
    dangerous?
    well if you think about it yes but then again what in life isn't dangerous
    search the boards and you should get your answer
    • Stephen Vick
      • Mar 2005
      • 64
      Hi,
      I built a ROG type
      Hi,
      I built a ROG type VII using the Small World Models wtc, and I found that there was plenty of space in the bow for at least 2 tubes. I think it should be easy enough to do. I build my Torps so that the nozzle fits into an O ring at the breech end of the tube.The nozzle is simply a small brass tube which extends halfway into the torp body to restrict flow. The O ring connects to a tire valve through which I can fill the torp with propel. A simple lever in the breech (actuated by servo) pops the torp off the O ring and off it goes. I do this with 1/32 and 1/48 scale torps, I see no reason why it wouldn't work with 1/72 scale. Dave merriman uses the same torp design in 1/96 scale and uses air pressure to launch. He has made every tube in an Akula and I beleive a 1/96 Skipjack work in this way. I say give it a try, I would but I gave that boat away.
      Good luck,
      • tabledancer
        • Feb 2005
        • 573
        sounds reasonable to me,do you
        sounds reasonable to me,do you have any pictures that you could post.
        TD
        • Stephen Vick
          • Mar 2005
          • 64
          I never built tubes into
          I never built tubes into that boat, but the space is there aplenty. I could send pictures of the install in one of my larger boats but they are far larger (even though the concept is the same). Anyway I am at sea and cant send any pic's.
          Look up some of the old articles by David Merriman for a workable torpedo design in that scale.
          Take Care,
          • tabledancer
            • Feb 2005
            • 573
            Thankyou for the info,maybe this
            Thankyou for the info,maybe this afternoon if I get some time I`ll check it out
            Be Safe Out There,
            TD
