Looking for help trimming my XXIII - Nose drops when i dive...
Okay - here is the damage to the conning tower on my 32nd P type XXIII.
The question is - how to fix it without having to re-build the whole tower. One guy has suggested splitting the tower, cutting out the busted back bulkhead and re-making it from styrene. Any other bright ideas?
Dose the tower come off the hull? If it dose, use some styrene as a backing on the inside of the tower. Fill in the cracks and holes with some body filler. Sand it smooth and add the details back in.
I ran it by Dave Merriman (God's gift to modelling ) and he suggested - no, actually he TOLD me the following:
Yeah, cut just below the radius between side and top of the sail (the portion aft of the crushed vertical bulkhead). Use a razor saw to reduce kerf (you can make that up with little dabs of cured CA forming 'lifts). Yank off the top, grind off the vertical bulkhead either side of the scope foundation (if the foundation is bent us a small diameter cutoff wheel and removed the bent portions and graft on a new foundation cylinder), rebuild the bulkhead and redress the bridge area as required. Reinstall the top portion of sail and Evercoat the union between the two.
Is the sail removable from the hull? That would simplify things. If not, then take it as a lesson learned and make all your boats sails (but not the modern Russian stuff) removable from the hull!
Who am I to argue? That's how I am going to do it! I'll let you know how it works out.
Interesting idea, but I think G-10 would be overkill for that purpose. I wouldl have to bond it to the surrounding ABS which will still be the weak point. I'll just keep it away from flailing purses from now on
I love G-10! ...but it's definitely not the correct material for this job.
I would not cut the top off. That's just making more work than is necessary. I would repair the aft wall section by gluing a piece of ABS to the inside and glue the cracked sections back into their correct locations. (Of course, the use of ABS cement is highly recommended!) The new backing providing the needed support. Then apply a minimal amount of ABS filler to the exposed, cracked areas and then sand it back to the correct profile.
Shouldn't be a very difficult or lengthy job.......
hey Tim,, Ouch...
I noticed the hatch sitting on the (floor).. should actually be up off the bridge deck. Why not pop the hatch and hatch platform off the floor, use a piece of .o40 , .020 styreen about a half inch wide, curve it around cornor to cornor, reattach the hatch platform to the top of this ... this will cover, hide, at least half of the damage giving the tower a more scale look, then use the same material and cover up or "hide" the back wall on each side of your scope post.
In other words when your done and looking into the tower you will see a "U" shape platform with the hatch sitting on top. I did something similar to mine.. and worked out great. However still have not laid down the cash to buy a WTC for it... ha ... ha... You can use testors model glue to assemble the styreen sheeting. I can send you some it you need it. Jeff J. BTW,, i finally got a digial camera,, if i figure out how to post a pic here i will get a close up of mine.. see you in a few weeks...
