Speed controller
  • wingtip
    • Dec 2004
    • 335
    Speed controller
    bought a speed controller for my alvin today (still need another one too) but you cant beat this for the price..
    its called a Tazer19T from dynamite which is distributed from horizon...it has fwd and rev, weighs 1.8 oz , input voltage of 4.8-8.4vdc, peak current of 500amps, and bec 5v/1A@7.2v
    all for
    $29.99
    not bad for the current rating..it doesnt say what continous it will handle but i imagine its up there if it will handle peaks of 500amps...
  • collins class
    • Dec 2004
    • 128
    Hi Wingtip
    I came across an
    Hi Wingtip
    I came across an ESC for a similar price that looked like a good deal as well http://store.yahoo.com/raidentech168/fuescelspcof.html
    It is meant to be a clone of an MC330CR.
    Stock # Model Dimensions (in.) Weight (oz.) Capacity Motor Limit Current (fwd/rev) Wire
    B1006 OEM-MC330CR 1.07 x 1.31 x 0.50 1.59 6-7 Cells 13+ turns 200A/100A
    Also re:your Tazer. here is the info:
    Specifications
    Forward: Yes
    Reverse: Yes
    Time Delay Brake: Yes
    Continuous Maximum Current: 14 Amps
    Motor Limit: 19 Turns
    Momentary Peak Current: 500 Amps
    Dimensions: 1.77x1.61x1.06"
    Weight: 1.80 oz
    BEC Voltage: 5V/1A @7.2V
    PWM Frequency: 940 Hz
    Overload Protection: Thermal
    Full On Resistance: 0.012 Ohms
    Byron
    • collins class
      • Dec 2004
      • 128
      Something here I am unsure
      Something here I am unsure of, how do you determine the number of turns in the motor? For example how many turns in a Mabuchi FC-130?? The specification for the motor doesn't tell me...
      Byron
      • petn7
        • 616
        i think a more important
        i think a more important number is the Kv? i've never seen the terms "turns" or "winds" used for r/c motors except for those 540/550 sized modified motors.
        • chips
          • 494
          That's how many times the wire is wound around each armature. The wire is connected to the commutator and wound 27 times (stock 500 motor) the armature and then connected back at the comm. This is done for each lobe of armaturs, some motors have 3 arms, others have 5 or 7. On a double 13 turn motor, the wire is connected to the com, wound on the armature 13 times; the wire is connected back to the comm, and then wound a second 13 times before being terminated on the com.
          • collins class
            • Dec 2004
            • 128
            So how do I determine
            So how do I determine the number of turns in the FC-130 for example??
            • chips
              • 494
              If there is no specification
              If there is no specification on the number of turns, you might have to sacrifice a motor. Tear it apart to get at the armature, and unwind the wire from one arm, counting the number of turns as you unwind. The R/C car guys, and the fast electric boaters, seem to be the guys most interested in the number of turns on a motor. Might have to check some of those sites.
              Edited By chips on 1113235471
