1/72nd Uboat Gearbox; just about done
  • steve nuttall
    • Feb 2005
    • 140
    Here is the assembly pic
    The motor drives a 12 tooth steel gear
    1st reduction is 12 (motor) to the plastic 31 tooth; part of this same gear is a brass 8 tooth which forms the driver part of the 2nd reduction
    The next plastic gear is 34 tooth; and this drives an 18tooth
    This gear drives 3 steel 13 tooth shaft gears arranged so the outer 2 revolve opp directions
    I still need to add the actual shafts and seals etc; the gears are riding on 1/8" diameter carbide cuttershanks for testing
    Motor is rated 9-18volt 18,0000rpm it seems to run well on 12
  • turbobearcat
    • Apr 2003
    • 404
    The
    That's the radio shack motor I use!
    it powers my Uboat and IJN Musashi,maybe my son's Blue Devil
    Destroyer...
    good choice..
    Mark
    • steve nuttall
      • Feb 2005
      • 140
      cheap enough too
      cheap enough too
      • turbobearcat
        • Apr 2003
        • 404
        cheap enough too
        true true!
        cheap enough too
        true true!
        • steve nuttall
          • Feb 2005
          • 140
          shafts are now done too
          I
          I used silicon bronze for the output shafts; the gears are lock-tight'ed on after i knurled the outside diameter of the shaft to make sure there was plenty to grip; the gears I bathed in Acetone to remove every drop of grease-oil etc
          They should stay put
          I did add a safety device; between the 34 and 18 tooth plastic gears there is a 1mm shear pin
          My clearance from the hard nylon rear seal to the output shafts is about 0.0005" with melted grease added as i inserted the shafts (just warmed the shafts up a bit to melt the grease)
          I'm hoping this is close enough to stop any water getting in; I don't like the idea of o-rings (too much drag)
          If i need to; there is enough shaft length outside to add custom teflon lip seals i can make and fix to the rear seal
          • tennesseejim
            • 53
            What did you use for
            What did you use for the bushings? Also, where did you get the gears & bushings?
            Thanks -
            • steve nuttall
              • Feb 2005
              • 140
              Bushings; what bushings?
              I use brass
              I use brass to steel contact or plastic to steel/brass where ever there is rotation
              The silicon bronze is very tough
              • steve nuttall
                • Feb 2005
                • 140
                Gearbox installed into the WTC;
                Gearbox installed into the WTC; I just added model AC fuel tube in place of the dogbones i'll make
                I wanted to test the shaft supports and prop thrust; all seems well; the small amount of defection from the propshaft to the gear shaft is quite small hardly anything to a set of dogbones
                I was thinking of inboard bearings; but it just seems fine without
                  Freaking excellent Steve!
                  Steve
                  Steve
                  • collins class
                    • Dec 2004
                    • 128
                    Wow, impressive piece of work!
                    [color=#000000]Wow, impressive piece of work! ]
                    • steve nuttall
                      • Feb 2005
                      • 140
                      still need to make the
                      still need to make the rudder pushrod or screwshaft exit
                      I'm really thinking a high speed screw for the rudder; like a worm and quadrant setup; not sure yet (the advantage would be the servo output shaft could drive it direct)
                      Anyway thanks guys; if 2 experts liek you think it's good; I must be on the right track
