Don't get too excited just yet; brass props
    that works
    that works
    • steve nuttall
      • Feb 2005
      • 140
      Ok I'll have a good
      Ok I'll have a good fashioned auction
      Here are 2 brass props; with long version shafts; there are both hands i.e. 1 LH 1 RH both are already soldered and cleaned up but not profiled; you would need to file and thin the edges for scale apperance like the one pictured earlier (mine)
      The short shaft is there just to show the longer shaft is quite a bit longer (50mm)
      The shafts are normally $12 a pair for the short version
      I will be adding $4 for a pair of long versions anyway; so if we say the shafts are already $16 and as i have no qlue as to the price of the props I'll add another $16 for the Reserve at $32 (if I can't get that it's not worth my while making them)
      Ok guys you know how it works; post your bids; I'll let it run 3 days
      ends Sunday at 10.30 am
      • novagator
        • 820
        What are those for?
        Well to
        What are those for?
        Well to be truthfull; they rotate and propel ships or Uboats through the water; bigger versions with thiner blades can actually pull aircraft off the ground and make them stay in the air for as long and the device rotates; unbelieveable is it not
        They are called Propellers
        Smartguy! I meant which kit? As I can see now, it looks like they are for the Revell kit.
        • steve nuttall
          • Feb 2005
          • 140
          JUST HAVING FUN http://www.subcommittee.com/forum/icon_biggrin.gif
          JUST HAVING FUN
          • ron
            • 71
            Steve,
            Well I'll start at the
            Steve,
            Well I'll start at the $40.00. I was going to order the periscopes and gun barrel any way. We'll see how many takers there are. I figure they are worth at least that.
            Ron
            • steve nuttall
              • Feb 2005
              • 140
              Here's my set; all profiled
              Glad I made them; they look great
              About 3/4hour per blade to make them like this; a small sq file (needle) and 600 wet-dry paper
                Here are some periscope masters
                Here are some periscope masters I just sent Paul Crozier for the Thor/Crozier Type XXI kit in 1/48 scale. Spiral wire added around attack scope neck after this production photo was taken. Not geared for multiple custom work.
                Steve Reichmuth
                Edited By Dolphin on 1110051596
                • steve nuttall
                  • Feb 2005
                  • 140
                  Steve,
                  Steve,
                  Ron
                  Ron
                  It looks like your going to be getting a really good deal
                  • steve nuttall
                    • Feb 2005
                    • 140
                    Looks like Ron will be
                    Looks like Ron will be the winner
                    • steve nuttall
                      • Feb 2005
                      • 140
                      well my computer says 10.30;
                      well my computer says 10.30; guess Ron you got them
                      • ron
                        • 71
                        Steve,
                        Pleased to see I was
                        Steve,
                        Pleased to see I was lucky enough to get them, my gain.
                        I sent you an e-mail earlier, as they say the check is in the mail.
                        Ron
                        • steve nuttall
                          • Feb 2005
                          • 140
                          Ron please email again and
                          Ron please email again and not through this site; I can't seem to reply to you
                          snuttall@cogeco.ca
                          • ron
                            • 71
                            #28
                            Just wanted to let everyone
                            Just wanted to let everyone know I received the shafts and propellers from Steve, (I Also decided to get the gun barrels and periscopes). As I sure you have seen from the photos the workmenship is top drawer and will really add to the finish of the model. I highly recommend the parts.
                            Ron
                            • steve nuttall
                              • Feb 2005
                              • 140
                              #29
                              Hi Ron
                              I have to think
                              Hi Ron
                              I have to think how to protect those longer shafts and stop them from being bent in the mail; how did you like the solution?
                              • ron
                                • 71
                                #30
                                Steve,
                                Everything got here in one
                                Steve,
                                Everything got here in one piece. I guess you'd have to say your packaging was highly imaginative ( but functional). I was
                                thinking about options for packaging for you. Did you ever
                                try pvc tubing cut to the length of the product? You could use micro foam sheeting to pack inside and just tape ends. Alittle more costly than my packaging material ( empty ball point pen for scopes), but I think your buyers would put up with .50 cents more if it was even that much.
                                Ron
