Retractable Dive Planes
  • themongoose_OLD
    • Jan 2005
    • 26
    Hey gang, I tried a search and came up with very little. One specific question I had was which issue of the subCommittee has the instructns on how to build a set of RDPs? Then, in general, are there any websites out there that you know of with good pictures or instructions/tips & tricks? I looked at the engel site and the robbe site but there's not much detail there.
    Thanx
    Which sub are you modeling?
    Which sub are you modeling? The reason I ask is that retracts for a US WW II fleet boat are quite different than a say a soviet Typhoon.
    • themongoose_OLD
      • Jan 2005
      • 26
      I'm doing a 1/48 balao
      I'm doing a 1/48 balao boat. Forgot to add that!
        • 682
        Issue 33, pages 40-43
        Also, I'm
        Also, I'm currently doing a refit on my 1/48 fleetboat, and working it up as a couple of how-to articles for upcoming issues of The Report. There will be lots of pictures and diagrams concerning the retract system (and the rest of the boat)
        Jim Butt
        • themongoose_OLD
          • Jan 2005
          • 26
          Cool. I'll have to look
          Cool. I'll have to look for your articles. I'm trying to finih mine before the regatta this july. if there's anything you can share with me aghead of time I'd appreciate it. Thanks for th einfo on the SCR. I sent Don a request for it this evening. Chris.
          • jaschwink
            • Apr 2004
            • 56
            Chris,
            I'm building an Engel fleet
            Chris,
            I'm building an Engel fleet boat and have their bow plane retracts. Richard Pflanzer is also building one and also has the retracts. They are fairly expensive, but are engineering marvels. Mine are not yet installed nor working, but they look good. Engel uses a motor to run a gear train via a toothed belt that further turns shafts that cause the planes to rig in or out. Really ingenious. The planes are interlocked with the pitch servo so that the planes must be level before the rigging motor is energized. The system has three relays, motor gearbox, plane gearbox and switches. If you wish further info, contact me direct.
            Jim Schwinkendorf
            jaschwink@aol.com
            • boss subfixer
              • Aug 2004
              • 656
              Jim,
              How hard would that be
              Jim,
              How hard would that be to convert over to a non engel setup? One of the pictures on thier site showed some sort of plug board.
                Here are a couple of
                Here are a couple of answers to the same question.
                Rich Kohbrecker's 1/48 fleet boat retracts.
                From "Simply Submarines"
                In a 1/72 Fleet Boat hull. This one deploys only, no dive or surface function.
                Edited By TMSmalley on 1109338763
                • themongoose_OLD
                  • Jan 2005
                  • 26
                  This is awesome. Looks simple
                  This is awesome. Looks simple enough to build. I'll give it a try! Thanks Tim
                  • themongoose_OLD
                    • Jan 2005
                    • 26
                    ok, $20 and some old
                    ok, $20 and some old parts from my RC car later and I have a layout for my retractable dive planes!!!! I thought the sketch Tim S put up looked doable. Can't [post a pic yet apparently until someone turns on my membership on here I guess. I'll post it on my webpage on this site. I used a driveshaft, ball and sockets, and a few plastic swing arms from my rc car in conjunction with 2 brass rods to cobble this together. I'll post an update when the kids are better and I have time to work on it more (2 out of 4 down with a virus right now).
                    Chris
                    • themongoose_OLD
                      • Jan 2005
                      • 26
                      ok, $20 and some old parts from my RC car later and I have a layout for my retractable dive planes!!!! I thought the sketch Tim S put up looked doable. Can't post a pic yet apparently until someone turns on my membership on here I guess, or maybe I have to host it somewhere? I'll post it on my webpage on this site. I used a driveshaft, ball and sockets, and a few plastic swing arms from my rc car in conjunction with 2 brass rods to cobble this together. I'll post an update when the kids are better and I have time to work on it more (2 out of 4 down with a virus right now).
                      Chris
                      • jaschwink
                        • Apr 2004
                        • 56
                        Further info on the Engel
                        Further info on the Engel Bow plane retracts. The mechanism runs via simple on-off switches that feed into Engel's relay board. What happens is the relays control the rotation of the motor that drives the retract mechanism. The motor spins 17 revolutions and shuts itself off when the planes are either fully rigged out or in. A normal servo controls the plane pitch. It is interlocked via a switch to ensure that the planes are horizontal before they will rig in. If the plane are out had have a pich, the motor will not engage to start retracting them.
                        A lot of thought and engineering went into the mechanism.
                        jaschwink
