Engel Laffayette - Bayonette ring
  • stingray
    • Feb 2005
    • 4
    I am having problems with the sealing of this unit, I have tried using the soft O rings with lots of grease but i still am getting the same sealing problems.
    Is there a solution without having to change the bayonette ring,? which would be a major job to try and remove.
    Are you sure it's leaking
    [color=#000000]Are you sure it's leaking round the bayonet ring?
    That kit has an aluminium bayonet ring, you really shouldn't get a problem with this, unless]
    • stingray
      • Feb 2005
      • 4
      ive just checked the bayonette
      ive just checked the bayonette ring and the surfaces seem to be pitted would that cause a problem?. if so what is the best course of action?
        Possibly. but it's difficult to
        Possibly. but it's difficult to say without having it in front of me.
        If the pits are really bad, then a light sand with some fine wet and dry may help.
        • stingray
          • Feb 2005
          • 4
          Thanks for the advice, ive
          Thanks for the advice, ive had a go and got most of the surface clean, just hope the test run works. had this sub for about a year now and still never got running right. its now or next stop ebay.
          Phil
            I'll give you a tenner
            I'll give you a tenner for it!
            • stingray
              • Feb 2005
              • 4
              Not a problem its yours
              Not a problem its yours for a tenner plus £340 p+p
