Drivetrain couplers - who else imports engel stuff
  • wingtip
    • Dec 2004
    • 337
    alexander engel has some nice couplers that are interchangeable... is there anyone else that already imports these and has these on hand here in the states?
    I would try www.subconcepts.com .
    I would try www.subconcepts.com . He is very much in touch with Engels, and sells the kits and parts. Very good to deal with, too.
    • wingtip
      • Dec 2004
      • 337
      thank you... i emailed him...
      • uss silversides
        • 197
        While on the topic of
        While on the topic of couplers, does anyone know where I can get some 1/4" universal couplings? It seems the biggest I can find is 3/16".
        Jonathan
        • wingtip
          • Dec 2004
          • 337
          i found some 1/4 inch
          i found some 1/4 inch stuff at dumasproducts.com but the other end is threaded so not sure if that will help...
            Not sure about the sizes,
            Not sure about the sizes, but Raboesch has a good line of parts that includes various sized couplers. Ships n' Things is a distributor of their products.
            • uss silversides
              • 197
              Thanks guys, I'll check those
              Thanks guys, I'll check those out.
              Jonathan
              • uss silversides
                • 197
                OK, a couple more questions.
                [color=#000000]OK, a couple more questions. First, when I planned how I was going to build my cylinder, I planned for one motor running two props at 3]
                • wingtip
                  • Dec 2004
                  • 337
                  i am purchasing a graupner
                  i am purchasing a graupner single motor dual shaft drive that was for the shark submersible they have...its small in size and will work for my thrusters on my alvin... its around 70 bucks as i recall though....
                  shafts are counter rotating but i can flip the prop on my graupner nozzles no problem.......
                  • uss silversides
                    • 197
                    Actually I built the gear
                    Actually I built the gear box myself. I used some gears that I got from an old laser printer and built the frame myself. It really runs nice and smooth. It will however be outside of the cylinder (because it is kind of large).
                    I have decided to use the one motor and the gear box though, as opposed to two motors and direct drive. I just think it would be a lot simpler (one seal, one cylinder, one central driveshaft, etc.).
                    How about my other question about the couplings?
                    Jonathan
                    Edited By USS Silversides on 1106869331
                    • tennesseejim
                      • 53
                      Can you post a picture
                      Can you post a picture of your gearbox? I'd like to see how you did that.
                      Thanks - Jim
                      • uss silversides
                        • 197
                        Here you go]http://www.81x.com/Authors/JDBostrom/1.JPG
                        http://www.81x.com/Authors/JDBostrom/2.JPG
                        This shot kind
                        Here you go]http://www.81x.com/Authors/JDBostrom/1.JPG[/img]
                        This shot kind of makes it look oval in shape but it really is circular. The nylon bearings are adjustable to allow some tinkering to try and get it to run its smoothest. I still have to install the bearings for the central shaft.
                        This is the small motor cylinder that I am building. The orange strips are adhesive backed silicone rubber strips from McMaster. After wrapping them around the motor, the motor fits nice and snug inside of the polycarbonate tube.
                        Jonathan
                        Edited By USS Silversides on 1106958152
                        • tsenecal
                          harbor models sells tons of
                          harbor models sells tons of couplers,
                          his are the type that are made of 3 pieces like a u-joint on an automobile drive shaft. he sells them in parts as well, so you can get a 6mm to 4mm adapter, or a 3.2mm to 4mm for example.
                          then choose "propulsion", and at the bottom of that page he has stuffing boxes and couplers listed...
                          • tennesseejim
                            • 53
                            Thanks for the pictures.
                            Where are
                            Where are you getting the bearings?
                            - Jim
                            • uss silversides
                              • 197
                              They are just nylon bearings
                              They are just nylon bearings from ACE Hardware.
