Best ballast system
  • thierryc
    • 162
    Best ballast system
    Hi all
    I am looking at the various ballast systems. I don't want to use propel, piston or pump, And I am kinda torn between compressor and CO2 system.
    I know that the compressor system is what the real ones use, and I can do as many dives as I want as long as the batteries are ok, also I can use the compressed air for hydrolics and other fun stuff like torpedoes, etc...
    However it is a bit on the pricey side and require a good dose of electronic to implement everything I want.
    On the other hand a CO2 system is cheaper, not as complex, and the parts are available at any paintball shop.
    The problem is that I have to count my dives, the pressure is pretty high which can be dangerous in case of problems.
    Let me know what you think.
  • rockpile
    • 48
    Hi Thierry C,
    I have a
    Hi Thierry C,
    I have a CO2 system in my Type XXIII. It works very well, but was a bit more expensive then the compressor system that I have for my 1/32P Fleetboat. The systems are almost the same . The biggest difference was the regulator for the CO2 system which cost anywere from $79.00 to $165.00. The compressor cost me just over $35.00 and will only charge the system to 225 PSI (if you are lucky). Most of the time I only get a charge of about 125 PSI. I use an electric pressure switch on the tank that is set for 110 PSI. That switch was only $18.00 at Home Depot. All the other valves and solenoid are the same in both the CO2 and the Compressor system. If you use the clippard solenoid they have a built in safety valve that pops at 125 PSI. Send me an e-mail if you have anymore questions.
      [color=#0000FF]]
      • dietzer
        • 255
        Thierry,
        I'm new to R/C subs,
        Thierry,
        I'm new to R/C subs, but isn't it possible to just use the compressor to empty the air out of the ballast tank and into a storage tank ? Then you shouldn't need 120 PSI air pressure for your ballast system. And the smaller the pressure, the smaller the compressor, the less you run the compressor, the faster you're ready to dive again, the more battery time you have, etc.
        I've been thinking about using the small cans of compressed air found in bike shops for emergency inflators. These have enough air to pump up one or two bike tires (most are CO2, but a couple are simply compressed air). Maybe use two of these cans of compressed air (they're not much bigger than a medicine bottle); one for normal usage and one reservered for emergency blows. Then just use the compressor to empty the ballast tank back into the normal storage can. This should limit the air pressure to normal tire pressure, 35 PSI or less. Surely that's enough pressure to empty a ballast tank of water...
        Just a thought. Feel free to tell me I'm crazy -- my wife does so frequently!
        Carl
        • thierryc
          • 162
          I am interested in the
          I am interested in the idea of having an air compressor or cannister of CO2 at high pressure because I plan on using the compressed air to control actuactors (periscopes, dive planes retracts, etc...), to charge the torpdoes with the compressed air and to expell out them out of the hull.
          If I use a recirculating compressed air system I would not be able to use that air for anything but blowing the ballast tanks.
          Dietzer, what you are describing is pretty much the system that Art is using
          It is a good idea but cannot provide me with HP air
            I'd be inclined to use
            I'd be inclined to use a combination of both systems.
            I am a personal fan of the recirculating compressed air system, and it is the most used system here in the UK.
            Use CO2 solely for the torpedo firing.
            Or you could use baby pager motors for propulsion- depending on scale of course!
            • thierryc
              • 162
              The problem with low pressure
              The problem with low pressure is that I need a pretty big storage tank, my ballast tank is about 4L, if I use air at 35psi this means that I will need a storage tank of 1.3L. I think that such a big storage is a waste of space, and that by using a higher compression I could get a smaller storage tank and more blows out of one fill.
              Unless I am wrong in the way I calculate the volume/pressure ratio.
              Edited By ThierryC on 1046204366
              • guardian
                • 18
                Art I tried sending you
                Art I tried sending you a pm and it would not allow it for some stupid reason any way I would love to know more about Recirculating Compressed Air Ballast Systems. So please feel free to e-mail me,
                Mike
                  Mike,
                  Another source of information (as
                  Mike,
                  Another source of information (as well as complete dive modules) for the recirc. ballast type would be Bob Dimmack of OTW. I've got one in my 1/32nd scale Type VIIC and *really* like it.
                  • guardian
                    • 18
                    Jeff what is the price
                    Jeff what is the price for these ballast systems ? is there a site ?
                      http://www.otwdesigns.com/ppj.htm
                      pricing and description can be
                      pricing and description can be found there.
                        The OTW web site is]www.otwdesigns.com
                        Pricing
                        The OTW web site is]www.otwdesigns.com[/url]
                        Pricing information can be found on the OTW web site.
                          [color=#0000FF]]
                          • feet wet
                            • 213
                            Hi Thieery,
                            I'm using CO2
                            Hi Thieery,
                            I'm using CO2 in one of my boats and it does work for ballast, but I'm not convinced its the way to go for scpoes and the like.Seal wear seems to be an issue with such cold gas.I'd like to offer another idea.compressed air. This works great for ballast control and scopes.It can also be dialed down to low pressure. Only two drawbacks,cost and the need for scuba certification to refill the tank.If you're interested e-mail me and I'll send pics and specifics.
                            • guardian
                              • 18
                              Art I can't find you
                              Art I can't find you e-mail address any where ? ! could you post it or e-mail me I have a few questions for you
