I have an inexpensive AM radio system and the range seems to only be a few hundred feet before I start noticing glitches.
Is this typical of AM systems or could it be that it is just an inexpensive system and that is all it is good for?
FYI - This is a 2 channel Kyosha system in a boat, (not sub). I've been trying to determine if something is causing the glitches or if the system only has a max range of a couple hundred feet. My FM systems seems to have a much greater range.
I assume that because FM systems cost more, they will give better range and are less prone to interference.
Your insight is appreciated.
Thanks - Jim
Thanks - Jim
