hey guys I am having a big problem with the msonik brand ESC in particular sub- marine 3(not submarine) I can't get then to do setup in the boat I I have built (customer) (IMARA)
all I get is a get flashing green light
setup procedure ios as follows after all connections are made press the setup buttom with in 2 seconds it will flash green then move throttle stick to full and press setup again it should now flash red move the stick to full reverse and pres setup again to get both red and green to light this should now be ready to use but no not in this boat I have tried them in other boats and on the bench in a motor test stand and they perforn flawlessly
the boat is quite large and uses hectoperm motors 12v the batteries I have in the boat are 2 12v 7 amp in parallel (one per motor)
I have checked all wiring for shorts none present and continuity is great instructions from manufacturer state if green continues to flash turn everything off and operate servo reverse I have done that (this radio is a pain you have to take it apart to reverse a channel) and no change the manufacturer states the if the green continues to flash you are trying to setup high point too close to neutral well duh I have in in neutral at startup
please help if possible thanks ca
