"Parking" a research sub (zero speed) at transmitter-selected depth
    Hi guys,
    maybe some of you also wanted to achieve this in the past and have probably a technical solution for this task.
    I intend to use Norbert Brüggen's pitch- / depth controller LTR as well as his ballast tank switch BTS.
    My approach is the following:
    • Trimming the sub (ballast) for neutral buoyancy (dive tank filled to some 75%). This volume for safe return in case of emergency, failsafe, etc. .
    • Using a linear slider on the transmitter for depth selection.
    • Sub shall dive to this selected depth and shall stay there (control loop).
    For my impression, the pitch- / depth controller with its integrated pressure sensor needs to "talk" to the ballast module in order to maintain neutral buoyancy at the selected depth.
    It is this real-time control loop that is required and I am pretty sure that the two BTS relais will be "quite active".
    In case it turns out that this relais-based solution is not the solution, one can substitude this stage by an analogue version, e.g. an OpAmp-based comparator (small hysteresis around zero), followed by a motor driver (bridge).
    Question: Has anyone done this before ?
    Thanks in advance for any hint !
    Cheers
    Volker
