WTC pump type
  • georget
    • Mar 2004
    • 74
    WTC pump type
    Hello All, I am nearing completion of my OTW Vangaurd kit and was starting to look into a ballast system. I am leaning towards a pump type. Does anyone have a diagram that shows how to build one? What parts to use, and what electronics I should incorporate. Also how long the ballast chamber should be.
    For information on working out
    For information on working out the ballast tank size, take a look at this thread.
    http://www.subcommittee.com/cgi-bin....+volume
    It's not possible to give you an estimate by email.
    For the pump system, you need to be more specific. Do you mean a water pump system, or do you wish to use an air pump (compressor)?
    Into a fixed tank or flexible tank?
    Vented or sealed ballast tank?
    Regarding electronics- do you prefer solid state, or will micro switches suffice?
    How about using a piston tank- The Engel 750ml tank would be most appropriate I think, and it's available off the shelf.
    Cheers,
    • david h
      • 199
      G'day,
      John slater wrote a great
      G'day,
      John slater wrote a great article for the subcommittee report Issue 52 March 2003 on his pump set up for the Permit (ships n things) that he built. He talks about the pump type he used there. (This is for a pressurised ballast tank set up).
      It's a good set up you may wnat to consider.
      regards,
      dave h
