1/72 (yes, 1/72) Typhoon Mega Build
    Good evening my fellow bubbleheads.
    Tonight, Saturday, July 18, 2020, I came home to this package leaning up against my door:
    Inside was a monster sized, 1/72 scale Typhoon hull. Here are a few photos of this beast sitting out on my patio wall. He comes in at 8 feet in length.
    To get an ever better sense of scale, here he is compared to the Engel Typhoon, which is known as a beast itself:
    Like many of you, I constantly bounce around from project to project, from boat to boat, and more often than not failing to get as much done as you want to. With summer half gone already and the limited amount of fun runs happening this year, I've pretty much decided that no new boats are going to get done any time soon. The Carmel fun run always puts a lot of pressure on to get something new running in time. But that's no longer happening.
    As such, and after tinkering with several boats over the past months, I've decided to whittle down my active projects to two: a 1/72 3D printed British Astute attack boat, which is printing now and has been for over a week, and then this Typhoon. I think I owe it to of boat of this size to give it everything I've got... to incorporate everything I've learned over the past 20 years in this hobby... and to make this my master stroke, so to speak.
    My goals are lofty, but obtainable with work. The plans for this boat include:
    1. Two 110mm OTW cylinders, each running its own prop, and connecting via plumbing the two ballast tanks for even distribution of air and water. Each cylinder will be lengthhy, most of them ballast.
    2. Operational bow torpedos. I have a complete working system created and released a while back by DMIII. They are of the correct scale.
    3. All missile hatches will be able to be opened, probably in groups, remotely.
    4. At least two functioning missiles. I will be using nearly the same system that Kevin McLeod uses very successfully on his Kursk boat.
    5. Bow thrusters, almost an absolutes necessity for a boat this large.
    6. MP3 player and speaker system. Naturally, samples will come from Hunt for Red October
    7. 3D designed and printed appendages, as this boat only comes with the sail, nothing else.
    I'm sure more will come up as things progress.
    As DMII always says, "Just build SOMETHING!". Well, this is my big 'something'.
    Comments, thoughts, insights, help, criticism, whatever is welcomed and encouraged.
    -erich
    Holy crap, that is a monster hull. Your plans for it sound pretty awesome. Good luck with the build! (Article forthcoming?)
      Wow, that hull would make a great carrying case for my whole fleet! Looking forward to the missle battle with Kevin's boat.
      • steveuk
        • 467
        A monster project! I like your pragmatic plan to concentrate on just two builds. I recently had a discussion about all the projects we want to build and not having enough time to do them all. The problem we have is the internet has given us so much detail. Like crazy amounts of detail. Like we've never had before. And all that detail makes us want to model it. My conclusion is - this is what model building is about, researching and then building it into our models. Whittling down the long list of projects seems inevitable. Unless... we can increase our build speed. I cant bring myself to just two, just cant do it. So this is what I am trying to do, increase build speed.
        I look forward to seeing your monster Typhoon build. I do like Typhoons.
        • Ben Brigham
          • Sep 2019
          • 75
          Fantastic, Eric! Looking forward to seeing it in the water!
          Maybe you should paint & detail it in the "post-Perestroika" condition, with rusted rivets, streaks, missing tiles & tons of bird shit.
          (Y'know, just a bit bigger and you could get in and drive it to the next Fun Run.)
          BB
            • 1545
            What a monster boat Erich! Hope to see it in Carmel next year. Will it fit in your car, or do you have to tow it behind? Have fun with your builds and stay safe.
              Don, I haven't done a car fit test yet. I drive a Jeep, but a very compact one. So more than likely I will have to modify my trailer to carry it. Luckily it only has to go a few blocks down the road to the reflecting pond
                Erich,
                That will look amazing on the water. How deep is that reflecting pond? You might be scraping the bottom while still on the surface! That is a project that you can go as crazy as you want in detailing. Look forward to your progress on it!
                  • 1545
                  Can’t wait to see it in person. It is very impressive. Hopefully the Admirals sub launcher can handle it.
                    I've been concerned about that very issue. For as massive as it is, it's pretty lightweight. But with everything built who knows how heavy it will get. And then considering lifting it out of the water... ugh!
                    • chips
                      • 498
                      Maybe a canoe or kayak roof rack for transporting that beast. Remember when Johann would show up with the subs strapped to a roof rack.
                      • lhdockyard1
                        • Dec 2011
                        • 325
                        So I have to ask, where did you find that hull? Truly impressive.
                        • coryhenry
                          • Jun 2020
                          • 107
                          At that length its two big to even fit in my pool
                            • 1545
                            No worries. We have a lot of folks at the pond to help you launch and retrieve the boat. You might consider a pair of heavy straps with a rod so you can get the boat in and out without getting wet. Jim Butt uses a similar system on his big boat.
                            • tom dougherty
                              • 1364
                              Forklift??
