hey gang I need advise I have installed 4 sound boards in a robbe u47 and seem to have some jittery problems with the aft planes servo when the sounds are activated
this is how its all connected
motors and bow servo as well as rudder are in the rxand work great
there is a robbe 12+2 decoder(f14 navy radio) installed the ram instructions are quite simple and the activation board for the sounds is servo driven so that is on a servo channel and works fine but when I coonect the aft planes to ther other servo channel on the decoder and activate the sounds the aft planes go nuts jitter up and down ( they are connected via an apc4 )
what could be causing this to happen ?
I checked all contections for any lose fits and all is well
I am not sure if dirty wiring could be the culprit as I have not separated the dirty form the clean
please help
I would like the aft planes to be independant form the bow but if this mystifies with out a clear solution then it will have to be connected via a Y to the bow planes what would this do sonce the bow is run thru a ADC
please help
chuck
please help
please help
chuck
