Servo chattering
  • secrtwpn1
    • 269
    Servo chattering
    The last few times I've fired up my Subdriver, the servos for the rudder and aft planes chatter. All batteries are freshly charged. What causes this and how can I fix it?
    Thx
    Farlan
    How close is the Rx to the speed controller?
    Does the main battery wires that go to the main motor pass close to the Rx?
    What type of seal is on the rudder control rod where it exits the cap?
    You refer to the rudder servo.
    Do any other servos chatter?
    Several things can effect the servos.
    It is a matter of checking and eliminating sources.
    • secrtwpn1
      • 269
      I will check those things. Thank you!
      • secrtwpn1
        • 269
        I don't believe its the cylinder seal as I have been using this cylinder for several months. I'm in the process of moving things around in the compartment. There is only so much room!
          Wait. . .? something is wrong if you have room! <G>
            What type of radio & receiver do you have in your boat?
            • secrtwpn1
              • 269
              Vex and the receiver i bought from you a few years go.. I just pulled them out of storage. I did have a Sombre 8 rx in it
              and I think it died.....
              • secrtwpn1
                • 269
                So when i have the engine compartment out of the cylinder, it works fine. When I shove it all together, the servos start chattering. What parts should not be close to each other? I've never had this before......
                  I would start with the easiest step.
                  Make sure the Tx is not sitting on the bench with the Rx.
                  I move my Tx about 15' away.
                  Antenna overlap does strangthing uphere in the desert.
                  Second I would change the servos for testing purposes.
                  Move the rudder in to the elevator socket and the elevator in to the rudder socket and see if there is still the chattering and make a note of which servo it is.
                  If the elevator servo now chatters, you know it is not the servo but something else
                  It's the channel.
                    What frequency are you on, 75.XXX?
                    • secrtwpn1
                      • 269
                      Yes, 75.......
                        Farlan, is that channel 75 = 75.670 MHz
                        Other channels on 75 mhz.\ that we can use.
                        75.410 MHz --- Channel 61
                        75.430 MHz --- Channel 62
                        75.450 MHz --- Channel 63
                        75.470 MHz --- Channel 64
                        75.490 MHz --- Channel 65
                        75.510 MHz --- Channel 66
                        75.530 MHz --- Channel 67
                        75.550 MHz --- Channel 68
                        75.570 MHz --- Channel 69
                        75.590 MHz --- Channel 70
                        75.610 MHz --- Channel 71
                        75.630 MHz --- Channel 72
                        75.650 MHz --- Channel 73
                        75.670 MHz --- Channel 74
                        75.690 MHz --- Channel 75
                        75.710 MHz --- Channel 76
                        75.730 MHz --- Channel 77
                        75.750 MHz --- Channel 78
                        75.770 MHz --- Channel 79
                        75.790 MHz --- Channel 80
                        75.810 MHz --- Channel 81
                        75.830 MHz --- Channel 82
                        75.850 MHz --- Channel 83
                        75.870 MHz --- Channel 84
                        75.890 MHz --- Channel 85
                        75.910 MHz --- Channel 86
                        75.930 MHz --- Channel 87
                        75.950 MHz --- Channel 88
                        75.970 MHz --- Channel 89
                        75.990 MHz --- Channel 90
                        • secrtwpn1
                          • 269
                          I'm sorry. I misunderstood you guys. I'm on Ch 89......
                            It's okay, I am old and I may not say thing the way I mean them.
                            A question.
                            Do you have any channels near to the center of the channel group?
                            Before we go down that road, have your tried the servo swap to see if it's the servo or something else?
                              Another thought.
                              I know nothing about your radio.
                              Do it have the ability to increase or decrease the servo movement.
                              Sometmes when I adjust my servo through, I get it in a spot that does not seem to translate to the servo.
                              Some times dead spots of stalling mid movement.
                              If I increase the through percentage, these issues seem to go away.
