Basic Sub Questions
  • cadman
    • Jan 2004
    • 26
    Basic Sub Questions
    Not being a sub person, I will have many questions that will be old hat to most of you but I ask for your indulgence. What is the approx up/down angle of the dive planes? On another post someone suggested not using the plastic rudders and dive planes. I intended to use them and modify them with wire pivots at the outer ends (dive planes) and brass tube for the other pivots. Comments please.
  • novagator
    • 820
    What kind of sub is
    What kind of sub is it?
    • cadman
      • Jan 2004
      • 26
      See, I didn't even know
      See, I didn't even know that would make a difference.
      It's a VII. Sorry
        Cadman,
        The basic rule of thumb
        Cadman,
        The basic rule of thumb is to allow up to 30-35 degrees of deflection in either direction of 'neutral'.
        It doesn't really matter what kind of sub it is, it's more of a hydrodynamics issue. If the plane is moved beyond the 30 or so degrees it begins to act more like a brake.
        • cadman
          • Jan 2004
          • 26
          Thanks Jeff
          Thanks Jeff
          • koeze
            • May 2003
            • 204
            The exact values are just
            The exact values are just being discussed on the forum at U-boat.net forums.
            EJK
              uboat.net - always a good
              uboat.net - always a good place to get information on the real U-boats!
              (but I'd stick to here for the r/c types! )
