Kit to build a model submarine TR1700 "Santa Cruz-klass". Scala 1:30, a length 220 cm
  • firma555
    • Jun 2019
    • 179
    Sold a Kit to build a model submarine TR1700 "Santa Cruz-klass"
    The ARA San Juan (S 42) was a submarine of the Armada de la República Argentina (ARA), which disappeared in 2017 in the South Atlantic and whose wreck was located on the seabed only a year later. It was the second unit of the built in Germany for Argentina submarine class TR 1700th The class is referred to the type ship as the Santa Cruz class. The boat was named after the Argentine province of San Juan.
    Technical characteristics of the model:
    The kit is made in the scale 1:30 and has the length 220 cm and the width 25 cm
    Material:
    First coat - gel coat, which protects the parts from UV radiation as well as pressure damage.
    The interior 3 layers - GFK
    The kit consists of:
    1. The hull (consisting of 3 parts)
    2. Tower
    3. Horizontal stabilizers with depth rudders (2pcs.)
    4. Vertical supports with side rudders (2pcs.)
    A customer who purchased this model can also order a lead screw Ø 130 mm, which is designed specifically for this model.
    Technical characteristics of the screw:
    , The screw is made of carbon fiber and each blade is reinforced inside with a metal plate, which makes the screw very strong. That is not 3D printing from a weak plastic. The screw is very robust and is not afraid of sunlight or heat. This screw has a diameter of 130 mm and an opening for a drive wall of 8 mm. Upon delivery, you will receive a 25 cm stainless steel drive ramp on which the screw can be easily fastened with a M5
  • schaffer hasse
    • Mar 2013
    • 55
    I like the sub of Lazar Kerzmann they are superb welcome to the forum
    your fan of Kanada
    marcel
    • firma555
      • Jun 2019
      • 179
      Hi Marcel, thank you very much for evaluating my models.
      Lazar
      • firma555
        • Jun 2019
        • 179
        I am selling the matrix for making a model of the
        Submarine TP1700 in 1:30 scale (it is long models 220 cm).
        The ARA San Juan (S-42) was a submarine of the Republic of Argentina (ARA) that disappeared in the South Atlantic in 2017.
        Matrices of the highest quality have a polished mirror surface and enable the production of a model that does not require any additional processing.
        On one of the photos you can see the model made from these matrices.
        The complete set includes:
        1. Matrices for the manufacture of the fuselage ------ 3 pieces.
        2. The matrix for the manufacture of the tower of the submarine
        3. Matrices for the manufacture of stabilizers and rudders for depths and turns
        4. Device for precise punching in the wheelhouse.
        Preis 2200$
        You can buy this item in installments
        Mein E-Mail: lazarkerzmann@gmx.de
        Because of the heavy weight - only collection
ID:	133922 Click image for larger version
ID:	133923 Click image for larger version
ID:	133924 Click image for larger version
ID:	133925 Click image for larger version
ID:	133926 Click image for larger version
ID:	133927 Click image for larger version
ID:	133928 Click image for larger version
ID:	133929 Click image for larger version
