Set for construction of a submarine type XXI, scale 1:48, length 160 cm.
  • firma555
    • Jun 2019
    • 179
    sold a set for the manufacture of a model submarine type XXI in scale 1:48
    The length of the model is 160 cm.
    The hull of the boat is made of fiberglass. The rear stabilizers are glued into the hull. Holes (Ø 8mm) for stern tube are drilled. The flood slots are milled and the lower flood slots are closed from the inside with a layer of glass cloth. If necessary, these lower flood slots can be easily cut with a scalpel.
    2. The tower and 2 tower rifles are made using a 3D printer.
    3. The rudders and rudders are made of epoxy resin and have a Ø4 mm axis of rotation.
    4. In addition, the kit comes with the kit:
    Fumo antenna and other small parts for the tower and tower rifle (etched parts).
    Schnorkel - 3 D print
    Just to clarify; are you selling this kit, or are you building it yourself?
    It's a good looking boat; it looks like the tower is two pieces and needs to be joined? Will sanding the tower to remove the 3D lines cause loss of detail?
    • schaffer hasse
      • Mar 2013
      • 55
      Lazar Kerzmann is a rc submarine artist,it's product are manufactured by him and his for sale,that's hull are beefy very solid or by his distributor nautilus drydock USA Lazar is a seller with a great reputation in germany It's prices are excellent,the tower is made by one of his friends, it's the top of the top of the tower 3D
      • firma555
        • Jun 2019
        • 179
        thanks Marcel
        • firma555
          • Jun 2019
          • 179
          Hi Marcelb I'm sorry, but I just found your message. I am sending you the entire list of my works with prices. My E-Mail: lazarkerzmann@gmx.de
          respectfully
          LazarClick image for larger version
