Mini Pump Controller
  • Parallax
    • Aug 2017
    • 195
ID:	137617Click image for larger version
ID:	137618Click image for larger version
    I have been trying to put my Permit WTC together, and somewhere along the way the three wire signal lead detached from the controller. I cannot tell which pin is the positive vs the negative. Also I am not super confident in my soldering skills of something that small. It seems like maybe the wires are suppose to actually thread into the control board before soldering? Do you guys think I would be better off just getting a new one? Its less then 2 weeks till the last SubComEast fun run of the year and I'd like to be in the water at least once.
  • KevinMC
    • Sep 2005
    • 463
    I'm sorry to see you're having troubles with the MPC. The signal lead should come on to the board from the pump side, just like the power lead. The square pad (top pad in your third photo) takes the signal lead, the middle one gets the power lead, and the bottom one is ground. Putting a new lead on is easiest if you can clean out the old solder with solder-wick or a desoldering tool.
    KMc
    KMc Designs
    • Parallax
      • Aug 2017
      • 195
      Kevin, Thank you so much I'll give that a try tonight.
        • 682
        Mike, if you don't get it soldered, stick it in the mail to me. I'll solder it and mail it back in plenty of time for the run next Sunday.
        • Parallax
          • Aug 2017
          • 195
          Hi Jim,
          If it is not too much trouble I really appreciate it. I spent last night practicing soldering, and I just cannot seem to get it down small enough to trust it. I'll send it to you with a return label.
          Thank you again!
            Mike,
            I sent you an e-mail.....
            • Parallax
              • Aug 2017
              • 195
              Jeff, got it thank you.
              Jim I just sent the package with return label and package in it. Thank you so much!
                • 682
                No worries, Mike. Glad to help. I'll have it back your way the next day.
                  • 2342
                  Jim,
                  Love the helping heart! You ROCK!
