Engel Lafayette or Akula II?
  • SWESUB
    • Mar 2018
    • 14
    Hi,
    My name is Mats and I´m new here on Subcommittee, but I have followed the community since early 2000. I´m 45 years old, live in Gothenburg Sweden and own an old Engel Typhoon that I bought in 2003.
    I´m going to buy a new sub, and wonder about which one you recomend - The Lafayette or the Akula II? I like the Lafayette design and size more.
    Best regards from Sweden
    Just speaking from personal experience, the Akula was a nice, fairly straightforward build. Had it done in about three days. Jim Butt has one of the Lafayettes and it looks like it would be a nice build as well. If you're leaning towards that one, I would say follow your desires and grab it. Jim's maneuvers great and makes for an imposing presence in the water.
      I don’t think you can go wrong with either boat, but I have no experience with the Akula.
      I bought the Engel Lafayette in 2004 and launched her in early 2005. In fact I have run her every year since then. It is a great kit to build and run.
      Last year I did my first overhaul of replacing the two battery packs and some water lines. Other than that she has had no real problems and always runs great.
        There is one difference between the two kits that you may wish to take into consideration:
        The Akula II kit comes with a hull that is already assembled and painted. The Lafayette will require the type of hull construction as the Engel Typhoon.
          • 684
          Hello Mats, and welcome!
          I own both the Lafayette and a 212a, (the 212a is basically the same as the Akula II except with an X tail) so can comment on both.
          Jeff is mostly correct in that the Lafayette will require much more hull work than the Akula II to build. The Akula II hull is pre-built and painted, and so assembles very quickly. Both boats use the locking bayonet ring method of sealing the hull. (the Typhoon uses a dry box and a hatch).
          The other consideration is size. The Akula II is a fairly small boat, and can be easily stored and transported. The Lafayette is a significantly longer boat, and thus takes more room to store and a larger vehicle to transport to the lake.
          Either boat is a fine choice, and you really can't go wrong with either one. I'm very pleased with both of them.
          Good luck, and let us know what you decide!
          Jim Butt
