1:150 German Luxury Liner TS Hanseatic
    30 days left...
      • 343
      Nice progress!
      Better get started carving all those little people for the decks....!
        ha.... believe it or not i found a site that sells figures in 1:150 scale
          • 361
          How are things progressing Erich?
            What a pretty ship. Keep going, Erich! Looking forward to seeing it completed.
              I'm not going to meet my goal of Sept 16. Life is just getting in the way. I'll start back up again when I can.
                • 343
                We hope you are still able to make it up for the fun run/picnic!
                  I will definitely be there
                  • Rick Teskey
                    • 217
                    Fs1 update?
                      Haven't got to it yet, Rick. I may bring it though so you can help me troubleshoot it.
                        • 343
                        Theres a handful of them in the 8 balls group, lots of help available at the picnic.
                          Well, it's been over a year. A bit longer than my 33 day goal. But I've got this beauty on my bench as my winter project.
                          Below are a few pics of the kit that got deleted from the original post.
                          I'll keep you updated.
                            • 343
                            #28
                            Quite nice lines on it, hope you can bring it up in the spring!
                              My first step is to determine how much ballast I need to get the ship to sit right in the water. This may seem a bit backwards, but I will have ballast (in the form of lead shot) in spaces fore and aft that I won't have easy access to once the boat is fully assembled. So I built a test tank out of some inexpensive poplar boards. Note the drain hole in the north-eastern corner. There's a valve on the outside that connects to a 50 foot silicone hose that I have, used to drain and fill my fish tanks from a distance. I filled all the seams with silicone, and will let that dry overnight. Tomorrow I will line the inside with a coat of Flex Seal paintable, yeah, the stuff you see on tv. I've used it to seal cracks in my basement and it works like a dream. wish it smelled as good, though! Yuk! While waiting for all that stuff to cure, tomorrow I will do a little surface work on the hull.
                                • 343
                                #30
                                Didn't just want to test in one of your fish tanks? 8-)
                                This test box should work as a travel box too...
