Prop shaft seals
  • Telusboats6
    • Jan 2016
    • 25
    Prop shaft seals
    Could someone tell me the sources of prop shaft seals?
  • SubtechRC
    SubCommittee Vendor Member
    • Feb 2017
    • 87
    What prop shaft seal do you need?
    Best Regards,
    Matthew Thor
    Owner
    Subtech, LLC
    info@subtech.biz
    • Telusboats6
      • Jan 2016
      • 25
      Prop shaft seals
      I have a wtc and want to have 2 seals for the prop shafts to go through. I have looked online but have not found any being sold.
        ...I think Matt is asking what is the diameter of the prop shafts.....
        • SubtechRC
          • Feb 2017
          • 87
          Subtech is producing a premium line of pushrod and prop shaft seals machined from brass. The 1/16" pushrod seals utilize a machined packing gland and o-rings. The 1/8" and 4mm shaft seals utilize cup seals. We can work up custom seals from the same brass stock in any size desired, including 3/16".
          One of the neat features of these seals is that there is a beautfully machine threaded cap that allows instant access to the seals for oiling or easy replacement.
          Best Regards,
          Matthew Thor
          Owner
          Subtech, LLC
          info@subtech.biz
          • jure george
            • 361
            Any chance to see pictures of the seals? Also their prices?
            George
              • 375
              I have used seals from mikessubworks in the past
                I've got 1/16, 1/8" and 3/16" in stock and ready to go. You can hit me up by email at sales@nautilusdrydocks.com and I'll work up a price depending on how many you need and where you want them shipped to.
                • SubtechRC
                  • Feb 2017
                  • 87
                  The Subtech seals will be available as soon as the website is up. There will be plenty of photos. These are premium seals. They are fabricated from brass and are all CNC machined then polished. They are not cheap and are meant for the discerning sub modeler. The 4mm and 3/16" shaft seals are $25.00. Custom seals can also be made to order.
                  Best Regards,
                  Matthew Thor
                  Owner
                  Subtech, LLC
                  info@subtech.biz
