Polks Tracker II & III
  • Oldus Fartus
    • Jul 2016
    • 185
    Did these come in 75 MHZ?
    If not can they be converted (I think they are both synthesized)?
    • 2349
    Yes the Tracker III did come in 75MHz. Because of the synthesized crystal, they cannot be converted.
      ..or perhaps it should be noted that as far as we know, only Polks Hobbies had the means to convert between 72MHz and 75MHz......
      It would be excellent if there was someone else who could do the conversions.
        • 2349
        Better said, thank you Jeff!
          I keep hoping that someone will see these kinds of posts and step forward with a solution....
          • crazy ivan
            • 659
            While this won't help the submariners, the Polk Trackers CAN be easily and inexpensively be converted to 2.4 gHz. They make a great transmitter for guys who also run targets. (Come on, admit it. You know who you are!) I did this to my 75 mHz Tracker so I can run my surface fleet in mixed company without interfering with the crowded submarine frequency channels. When I want to go back to running my subs, it easily switches back to the 75 mHz band. I expect the 72 mHz units can likewise be converted for surface use, and you end up with a radio that can store 99 different models. There has to be a lot of them out there that the fly guys would be happy to get rid of cheap.
            sigpic
            -George Protchenko
              I don't know the score with Polk sets, but many synth sets are a bit of a pain for third party tuners, as they are often locked with manufacturers codes. Unless these codes have been made available to outside service centres by the manufacturer, then it's not feasible to have the set adjusted by anyone outside of the company.
