Little Skipjack
  • secrtwpn1
    • 269
    Little Skipjack
    I've pulled out my 1/230 (I believe) Skipjack to do some more work (after several years). I'm using the D&E conversion. I need to drill a .10 hole for the wire on the aft diving planes. Where would one purchase that size of a drill bit? Also, I was test fitting the WTC and every time I pushed the plexiglass onto another section, the seal became unseated. Would it be OK to spread a small amount of Vaseline (or something similar) to make this easier?
    Thank you
    Farlan Clutters
    Hesperia, Calif
    I have used Vaseline and I use silicone grease on o-rings.
    For cylinder caps and for control rod seals as well as the propeller shaft seal.
    I put a little on my first finger and then pull the o-rings between my first finger and thumb.
    Ralph --- SSBN 598
    Phelan, CA
      MicroMark: http://www.micromark.com or McMaster-Carr: http://www.mcmaster.com
      • secrtwpn1
        • 269
        Thanks for the info guys! Ralph, you and I need to get together sometime. We're only a few miles apart.....
          Not that far.
          Hwy 18 and Sheepcreek is near where I am.
          Also SubRonLA gets together down at YORBA REGIONAL PARK, 7600 E. La Palma every so often.
          I think the next gathering is Saturday, July 16th but I am not sure of the date.
          7-8 show up.
          It is a small informal gather with some very knowledgeable sub builders and operator.
          First gathering 2014
