Good morning, all!
I've got a cylinder that I'm building right now for my 48th Type VII and I'm running an air pump that is controlled with the Caswell (KMC Designs) control unit. I also have a vent that is actuated by a solenoid. The solenoid draws too much amperage for the built in controller on the pump circuit board, so I'm running an SES-II to control it.
The issue I'm having is that the stick direction for activating the pump and for activating the vent are both in the same direction. Basically the same stick direction activates both functions in one direction and nothing happens in the other. I need to reverse either the SES or the pump controller, but I have no idea how to do it without the use of an additional servo reversing module. For now I just have the two functions on a different channel. Worst case I can do that long-term as I have channels to spare, but it's a bit messy and I'd like both functions to be carried out on the same channel.
Any idea how I can reverse throw on either module?
Thanks.
Bob
Thanks.
Bob
