Homemade Typhoon
  • natesubs
    • Mar 2004
    • 12
    Sounds great. I will have
    Sounds great. I will have to pick up some and start learning how to mold with it. Sounds a lot easier then working with wood!
      Nate,
      Larry's Hobbies on 45 in
      Nate,
      Larry's Hobbies on 45 in Houston has a full selection of styrene in their model train room of the store.
      • wayne frey
        • 925
        Ok guys,
        Here is one for
        Ok guys,
        Here is one for you. Bob mentioned CA does not react well to styrene. I have some styrene parts to add as secondary features to my Alfa hull. Will not cement not hold with water exposure? If I am right there, what is the ticket for attaching styrene parts to a fiberglass submarine hull?
          Wayne,
          I'm not a chemical expert
          Wayne,
          I'm not a chemical expert (as I'm sure that some on these boards are), but CA will work, you just need to be careful.
          Where I ran into problems was when I had bent a piece of styrene out of its shape to follow the contours of my model. It cracked where the stress had been applied to the plastic.
          I think with careful application of CA, you should be OK. Maybe the thicker the better?
            I have found that if
            I have found that if you pre-form the styrene the application of CA will not fracture the plastic. But still keep the amount of CA applied at any one time minimal. Go back and add more later if necessary. I used this method when attaching the lifebelt track to my 1/72nd Skipjack hull. The styrene strip was something like 0.020" x 0.020" in cross section.
            Also, a CA bond will dissolve when exposed to water for long periods of time. The 'fix' is to make sure that the glue joint is painted over, essentially giving it a barrier to the water.
            • captain nemo12
              • Sep 2003
              • 279
              Nate, if you want to
              Nate, if you want to know about styrene, I'll help. Yes, styrene do come in different thicknesses, the ones I use are 0.30" thick. 0.20" or 0.16" ones are pretty easy to band. Yes, CA glue does work on styrene, I didn't really apply much on mine but I don't think you should put too much either. I will take pictures of the inside and provide a link to the picture this time.
              • natesubs
                • Mar 2004
                • 12
                Nate,
                Nate,
                Sounds great, I'll drop by there the day I get back from Lubbock.
                • natesubs
                  • Mar 2004
                  • 12
                  Thanks, I'll need all the help I can get! I'm planning on getting my Sub project(s) up and running by the end of summer, or sooner if that.
                  • topgun
                    • May 2003
                    • 17
                    Goto home depot and buy
                    Goto home depot and buy a can of "Great Stuff", it's foam that expands and is sticky as heck. Doesn't seem to destroy the foam and seems to hold up well.
                    -Tom
