I'm Worried - Are these holes too  large?
    • Nov 2026
    Here's my Dumas Akula. I'm trying to make it like Dave Welch and others have by creating a more scaled appearance. Anyways, I've been cutting out the 40 square holes on the sides of the boat and I need a second opinion. Do they look ok? I know that they're not exactly square and perfect (This is my VERY first R/C sub) but (with some black paint over them ) do you think they'll look ok? Here's a link:
    http://www.hpphoto.com/servlet....5&size=
    http://www.hpphoto.com/servlet....a&size=
    Does anyone have any suggestions for cutting these holes out? I've still got 12 to do on the other side. Thanks a million for the help!
    -Brady
    BTW the black and gray marks are sanded off magic marker and Tamiya Putty.
    Edited By Brady on 1073276737
  • uss silversides
    • 197
    I need a professional opinion
    I
    I can't give you that, as my experience with stuff like this is very limited. (I am also working on my VERY first one) But on my scratch built Gato, I also have a lot of holes to cut.
    First, if I am going to be making a lot of the same sized holes, I make a stencil, first on the computer, then I transfer it to some thin material. Then using the stencil, I trace out the hole with a pencil. (I have also thought about taping the stencil to the work then cutting the hole) Then I drill the hole out and shape it carefully with a Dremel. Next I use needle files to clean up the rest.
    This is probably just about what everyone does!
    Edited By USS Silversides on 1073267843
    • wayne frey
      • 925
      I would like to know
      I would like to know where you got that little scale flag on the sail?
      If the holes are too big,then not by much. I worried about the same thing on my alfa.(My first hull).Hey, you can always submerge if you feel self concious. I am no expert,but I think it will be fine.
        As for the topside flag.
        As for the topside flag. I scaled a pic of the Soviet Naval Flag down to 1/2" long and then compied & reversed the image and put the two together at the ends leaving a small space between them. I printed this out on paper and after I cut it out, glued it around the end of a swing pin with the head removed. After that, I stuck the flag right where the crew hatch would be.
        -Brady
