Airbrush advice needed
  • koeze
    • May 2003
    • 204
    I intend to buy myself an airbrush but since I never used one I'd like to know about your expiriences with them. Which one do you own and how do you like it.
    What would you recommend to an absolute (airbrush) beginner?
    EJK
    ___
    There are two basic types
    ___
    There are two basic types of airbrush - single action and double action. The single action is pretty much like a spray can - push the button and air comes out to push the paint out. It is best if you have a bunch of paint to put on like priming or base coat work.
    The double action, through the use of a trigger that also pulls back to control the amount of paint can do a lot more. If you have the option - start with a single action (much more forgiving and less touchy) and move up to a double - or buy one of each.
    I have a couple of Badgers and a couple of Paasche brushes and they all have their uses. I like the Paasche VLL best because it is left handed and a little easier for a lefty like me to use. Whatever you get, be sure to get a collection of the bottles that you can store the various colors in.
    A lot of guys are buying the Testor Aztek brushes and really like them, though I haven't tried one yet. Maybe NEXT Christmas!
    Also - find a good airbrush book or video and religiously go through EVERY excercise and master it so you know how to get the various effects; masking, spatter, fine lines, chrome, etc. - even if you aren't planning on opening a body and tanning airbrush shop in St. Maarten. (Hmmm, maybe a good retirement job! )
    Clean the brush thoroughly EVERY time. They can be VERY touchy if they get a tiny bit of paint stuck in the nozzle, needle, etc.
    Don't mess with Propel type products. As the pressure in the can drops, your spray pattern and paint texture will change. The more you use it, the can gets colder, causing a pressure drop as well. If possible get a tank type compressor to avoid the pulsing from a tankless unit.
    Use a moisture trap. Nothing is more frustrating to have a drop of water squirt out and mess up your job.
    and practice Practice PRACTICE!
    Paasche Website - go to the Products area.
    Testors website - go to products/airbrushes
    NOTE]Testors airbrushing models info.[/url]
    Edited By TMSmalley on 1072720971
      I have used a double
      I have used a double action airbrush (Badger) for more than 20 years...and just got a new Paasche VL for Christmas... (actually, it's on its way...they sent a "V" by mistake]www.airbrush-depot.com[/url]. They are actually sending me the new one without asking for the old one back til I receive the new one, and they didn't charge shipping or handling for the new or the return of the old, even though it was my fault (I picked "V" instead of "VL" on the online order form...) I used fellow member Dave Burkett's VL to paint my Type VIIc conning tower, and liked it very much. He also uses a couple of Iwata's which are high end artist type brushes for photo retouching, etc.
      Anyway, once you decide on which one you want to buy, go to their website. Great folks to deal with. Good prices.
      I agree with Tim...stay away from Propel too. Too expensive, too variable - get a nice small compressor. With Propel costs, you'll recoup the compressor investment in no time.
      Cheers,
      Sam
      Edited By sam reichart on 1072722708
        I've got an Aztec airbrush.
        I've got an Aztec airbrush. They're reasonably priced, and very easy to clean, as you just detach the nozzle and dump it in a pot of thinners!
        Re compressors, you can fashion a good airbrush compressor using an old fridge compressor. They run virtually silent too!
        • tommydeen
          • 327
          I have had a few.
          I have had a few. first i started out with an axternal mix by
          binks good brush but on externals you cant get a fine line like
          you can on an internal(depands on what you want to do with it) right now i have a testors/azteck its not bad, its an internal mix which makes it slightly harder to get it clean. one thing about the testor/azteck is that if you drop it on the floor
          it will instantly busts into a million pieces! been there done that lesson learned.. right now i have been using an Iwata and love it!!!! Iwata has come out with a new line of airbrushes. i picked up my Revolution 4500 CR for 89.98$ I also have an iwata i picked up at half off and it was still 150.00$ and piants a line thats supper thin!!!!!! the thing i like about
          IWAta is that they are all 1]www.iwata-medea.com[/url]
          • koeze
            • May 2003
            • 204
            I've decided to go for
            I've decided to go for a airbrush but all the stories of people having trouble with the cans of air made me build a compresor first. I found plans for a silent compressor using a fridge compresor and since I had a freezercompressor (big sucker) I built mine around that. I used a gas tank (propane) as used in campers and stuff like that (5kg) as a reservoir. These have been tested up to 30 bars.
            The first tests showed that it works great. 8 bars in 3 minutes looks good to me. I have some trouble with moisture in the air at present but need to fine tune the setup since my moisture trap does not seem to work.
            I'll keep you guys up to date and thanks for your replies.
            EJK
            • kd6hq
              • 102
              EJK
              You may find that you
              EJK
              You may find that you need more that on water trap.
              I use one on the output of the compressor and on the output of the tank. I have a friend that uses a long hose between the tank and the painting area so he uses a 3rd at the painting station. Good luck
              don
              • koeze
                • May 2003
                • 204
                I received a couple of
                I received a couple of emails where I found the plans for the compressor.
                This is where.
                Just follow the links on top of the page. They are scans from a magazine in which everything is described.
                Air brush compressor
                EJK
                Edited By KOEZE on 1075103563
