Organizer tip
    Organizer tip
    Ever wonder what you can do with your old pill containers.
    When you get to a certain age you seem to end up with quite a few fo them.
    Well all you need is some goop or RTV.
    Goop will hold better though.
    Just decide how you would like to set them up and then run a bead of Goop at the point of contact.
    Sometimes they do not match up close but the Goop will bridge the gap usually.
    Great for screwdrivers, X acto knives, small tools. Where they would normally fall over now they are supported by each other. Makes them easy to move around too.
    BTW They also make good ballast containers. Fill them full of pennies and you can move them around to adjust ballast.
    Hoping this helps.
    PS Don't be afraid to post any tricks you may have. BD.
  • chips
    • 498
    Re: Organizer tip
    A 6x9" plastic drawer organizer will hold up to nine 7.2V NiMh or similar sized battery packs. I got one a few years ago at Lowe's. I store the batteries with their leads pointing to the same side. When I cycle or charge my batteries, I put the charged batteries back in the box with their leads pointing to the opposite side.
